Daily Driver - out of warranty, time to modify! Baseline Dyno today!
Bone Stock - 2002 C32 AMG
Here were today’s results
First try the damn AMG Speedshift downshifted midway through the run (yes, this was with DYNO mode active), tricking the dyno a bit...to the amount of nearly 366 TORQUE! ...while I was like...holy ****, i figured the downshift in mid run would have to play havoc...
Getting straight to the point, the best run of the day
273 RWHP
281 RWTQ
for a bone stock, 59,000 mile 2002 C32 AMG... not to shabby
This was a different screen that they pulled up for me on the 3rd run, still solid on tq
Finally i ended the day with doing a "DYNO" Quarter Mile, i figured it would do a bit better than what she put down, but they were saying that if my reaction time was a tid bit faster and a little less wheelspin (yes, wheelspin on the dynowheel) on takeoff; I should of had a 8.8ish 1/8th and 13.6ish ...which is more in line with stock.
Net of the day, figure little mileage fatigued the car some, but its pretty near the 349HP/332TQ stock crank numbers after you figure the 20% to 22% drivetrain loss like most all cars.
So what direction should I go first? Pully/ECU? Filters? Intake? Exhaust?
What are your plans and in what order? What are your goals (handling, auto-x, bling, etc...) But more importantly, what is your general background/experience in car maintenance (will you do the work yourself?), but also as a driver?
I have the same car, have you dealt with the tranny jerk, glycol contamination, seat heaters, side-mirrors drifting, purge valve tapping, front bushings/swaybar rumbling, all 20 lugs simultaneously squirting off the wheels, A-pillar twisting into a balloon party-snake by a clown who pops out of the glove-box, every glass surface of the car beamed aboard alien space-craft, reverted to base elements, re-combined into popcorn and beamed back into place on the car.
This car is awesome, I love it, I always dreamed of having it, I feel like I'm participating in a legend, I haven't been able to get the ****-eating grin off my face for 4 months, I didn't want to drive it in the winter, but it's so f***ing fun I can't stop, I promise this will be the only winter it ever sees again, after this I'm going to mod, care for, and pamper it (to a degree
) but it's kinda junky until you take care of the common problems.That said, I think it will be excellent once we replace the components that are poorly made/engineered.
I'm going to do rims/wheels and suspension first (just springs I think, and see how it feels - cheap and easy), then driving classes, then chip, then more classes, then more exotic stuff like cams, headers, LSD, etc... much later.
That is unless I had a DB9. Then I would probably never get out. Is there room to sleep in the back of it?
if you want handling, go for the springs or COILovers if you have the $$
delete the resonator and add a greenfilter...
this will be for starters...
good luck!
If you can, get some Bi-xenons and some better shoes.
Let's see some pics!!!
