Resonator Removal
Resonator Removal
has anyone removed their resonator to get deeper sound from their exhaust? if so, im thinking of doing it to my c32, and want some help on how to. and is there any extra parts that i would need to complete the job?
2002 C32 Black/Charcoal
Here's the condensed version: It is a great, easy mod for the C32, and many people have done it, myself included.
Upsides: Better sound (subjective, but most agree), probably a few HP, lose 10lbs.
Downsides: Slightly louder sound, $50 for the labor, car no longer stock.
Parts: My guy went through like 4 cutting blades trying to cut the resonator off. Otherwise, only a piece of exhaust pipe to replace the resonator. Make sure your welder checks carefully for leaks before handing over the dough.
Good luck.
It's quick and easy.. Cost me $80.. Guy was done in 15 minutes max. He didn't break any blades. The only part was a piece of SS tubing about 12 inches long.
The sound is more aggressive, and was worth it to me.
Originally Posted by Bif powell
Good timing, I'm having this done on Tuesday of this upcoming week. Before I take it in, I'm going to get some video inside the car, idling, highway, outside pass-by's, etc... both before and after the res-delete with the conditions as close to the same as I can make them. I'll post it sometime late in the week probably. I'll try and remember to link to it in this thread also.
It would be really cool if you could get ahold of a decibel meter, as I think that a video cam mic is going to have a hard time picking up the difference (except maybe at launch).
Originally Posted by RBMBC32
Had this mod done yesterday at Lou's Custom Exhaust in Boston. So far I love the more aggressive sound.
Next MOD's - Suspension, Audio, and HP
thanks
can you post some sound clips?
thanks
thanks
MBworld Guru
white and whiter
look what you can find with search.
https://mbworld.org/forums/showthrea...+exhaust+video
the video includes sound from C32 with resonator removed.
1 Post
C55AMG W203; 330i E90
Originally Posted by Vomit
The change in sound is far more subtle than most people think. There is really not much of a diff, except under heavy throttle. My wife dropped me off the other day, and did a pretty hard launch. The car let out a loud "blaaaaaaat" which surprised me.
can we have someone tells us the difference sounds of C32 and C55 with resonator removal applied? I am tempted now after that RS4 guy showing off his exhaust sound but dont want to screw my stock pipes withour significant sound amplified , nor I want a AMG sounds like a Honda mod one.
cnt
Obsidian E55
http://video.google.com/videoplay?do...&q=c32&pl=true
AMG Grocery Getter
i wanted to get my resonator remove too but i went to two different shop and both shop said i might lose some low end power because these cars are tuned very well and little change could affect the performance so i decided not to ... anyone have an actual dyno with and without resonator? i had a 330 before and remove the exhuast and with remus exhuast and the car definitely feels like it lost some low end power ... but i don't know if it was because of the resonator removed or the exhuast since i did both at the same time
2016 C63s AMG
I was wondering what LDNA decided to do. I am curious about his low end power. i read that these cars(with superchargers) were built with the exhaust for a reason. I have a 2005 c230 sports sedan, it also has the kompressor engine, it came stock with 2.75 diameter exhaust. I was wondering if the Kleemann header and high flow cat is what caused the loss of power in the low end. The high end power is much more noticable now, but I would rather have more torque or at least the torque that was stock. Do you think adding another resonator would bring the car back to factory backprssure recomendations which gave me that torque I miss.
2016 C63s AMG
Originally Posted by 1FASTC32
by allowing a 4-cyl to breathe better it will lose some torque unless you turn up the boost some to compensate for the added flow...
a car that can't do the throttle reset.
anyone know what a 'supercharger muffler' is, and how to remove it?
the video in that link makes reference to it.
