Ran with a 911 Carrera
This thing is going to cost me a fortune in gas, tires and tickets but the smiles per mile will be well worth it.
Does removing the resonator make much of a difference in sound? Came from a 2000 Maxima and the sound of the c32 is perfect mix of quite when taking it easy and loud when you push the pedal. I may get used to it after a while and want it louder anyway.
i use 41 sometimes but mostly i'm on 94 north. maybe i'll see you around sometimes. i have black C55 w/ black center wheels and smoked tail lights.
make sure you add the green filter and remove the resonator...
its about 5 to 7 horses to the wheels and torque as well..
if you really want to stay with him neck to neck.. call up Evosport or renntech, they can prescribe the cure. Stage 1 (pulley and chip)
