ECU Reset Trick - Highly recommand! ;-)
C32 AMG
I don't think the ECU reset requires a waiting period after you switch on the ignition (not start) and hold the gas pedal down for 5 seconds. I think you're good to go after you let the pedal up (no 1 or 2 minute wait).
On Saturday I had to drop a kid off, then pick him up, at a particular location. Between those trips I did an ECU reset (just the gas pedal part), and running the same route twice, it was incredible what a difference it made. On two occasions, I induced rolling rear tire spins by hitting the gas (not trying to induce wheelspin, just an aggressive pedal).
I guess it's just a software change, and the only difference is the rate at which pedal pushing is transmitted to the throttle. But DAMN the car felt faster.
Highly recommand! (Sorry, I had to adopt that phrase.)
W203, W211, W219, W212
I think he's aware of that thread, hence his advise that there's no need to wait for 1-2 minute. This time he was just pointing out that he's so happy it worked.
Mine worked without waiting tonight before I left the office. I've heard others wonder if continuously resetting in this way (although it seems more like 'forced learning' or something) would do any damage or create some wierd programming down the road.
C32 AMG
Originally Posted by e1000
2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
I've read through both posts, and the open question is still... do you depress the gas pedal past the kickdown switch, or stop at the kickdown switch?
Thanks.
Thanks.
Thanks.
Thanks.
C55 ///AMG, 535xi
yeah it works, no need for the 2 min wait. i drove to my gf's house same route there and back. reseted the ecu when i got there, on the way back the throttle response was quicker, i think the wait is just optional lol
as for the kickdown or not, i press it to the kickdown, and i wait abt 10 seconds instead of 5
I just wait until the ignition beeping stops before removing the key - it's about the correct amount of time. No need to count seconds, or wait for two minutes after doing the procedure. I've gotten into the habit of doing this daily. I figure that will hold me over until I get the Sprintbooster installed
C32 AMG
THANKS a MILLION
Just went out tonight and tried the ECU reset, and one word
WHOA!!!
MY car slid sideways when hitting third, and ooooohhhh was it fun!!!
My hats off to JAKPRO1 for this GREAT TIP
Mramg1
WHOA!!!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Mramg1
C32 AMG
Tried the reset also. This is AWESOME for a "free" tune!!! Definately can tell a difference. The shifts are way better and a lot more squeeling of the tires. This will give me a reason to wear down these tires and get bigger wheels and tires... Thanks to whoever figured this out and posted it...
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
It's a perfectly valid question, but not to worry. The throttle is drive-by-wire, so there is no such problem. In fact, that's why the reset is needed!
02C32AMG
Too bad it's the middle of winter here in Chicago with 6" of fresh snow today, otherwise I would try it. Bookmarking this thread and will try it after the Great Thaw (read: April).
C32 AMG - in Pewter
No point in resetting the CPU in the middle of Winter. The CPU reset does not have a permanent effect, it seems to reset transmission control map to a default one, that is sporty and feels great, but that does not last too long.
Transmission will adapt to driving habits. I imagine that in the Winter, it will not take too long until transmission goes back to a less "aggressive" mode.
One way around that may be to reset CPU and then switch to Winter mode when in traffic. That will likely not affect the CPU reset/setting for the Standard mode.
I wish there was a button to tell the transmission to stop "learning" or adapting and hold current map.
