Renntech spring install gone wrong
just picked up the c32 and on way home heard suspension noise. i popped hood and found the "strut plate" (the black plate that's bolted on top the strut) 2-3 mm away from the rubber inserts below. so the whole spring strut can move up/down and this is creating noise and can't be a good thing. certainly the car was not like this with stock setup.
arrrrrrggggg. some times you try to save a buck and screw yourself. not that he was so cheap. i searched and found guys paid 150 - 1/2 of what i was charged. anyway....
does anyone know what or where things went wrong? does spring have to settle? i thought this was a straight forward install. my guy claims he bolted everything back together correctly. i was told to drive car and bring back to him on tues. i'm hoping there is a simple explanation/fix.
i also did h & r rear sways no worries there.
really would appreciate any thoughts or insight.
i don't use emoticons but
when i just want to be
the rubber on strut tower has an area that suggests that the plate was in contact.
late nite i did a some agressive cornering in an empty lot. it was raining but the balance of the car is great. just need to get this issue fixed.
thanks again.
Just take the nut off and rectangular metal piece. You can do this as long as the front tires are on the ground. On the threaded shaft you will see a circular nut with a couple of slots across from each other. Try to tighten that circular nut. It is about the only thing I can think of that may not have been tighten correctly.
now that the rain quit i took a good look and the top plate must conact the rubber bushing or else the top strut location can move around - changing camber and caster and prob be unsafe.
thing is i searched and found no one else with this issue. i posted a separate thread to ask how other folks' are sitting.
