pedal Install?
Old Oct 28, 2006 | 06:03 PM
spr's Avatar
spr
pedal Install?
Anyone personally install a set of pedal in their c55? I picked up a set off ebay mainly because I can't stand how the car doesn't have a dead pedal. However it appears you just screw the deadpedal through the carpet making holes???? Has anyone done this and what is the result can you see the holes when removed??? I am almost debating not installing them because I wouldn't want to destroy the carpet etc. Let me know. Thanks Sean
Old Oct 28, 2006 | 06:14 PM
rlee02135's Avatar
2004 C32 ///AMG
yea you have to screw it to the carpet. thats the only way
Old Oct 28, 2006 | 06:18 PM
spr's Avatar
spr
do you just screw it into the carpet or try and scew it into what looks to be the deadpedal mount under? So will noticeable holes be left looking lik ****?
Old Oct 28, 2006 | 06:38 PM
spr's Avatar
spr
I am thinking I might just get a bunch of velcro with adhesive back and sew the soft side into the carpet and then stick the other on the pedal. Thoughts?
Old Oct 28, 2006 | 06:46 PM
rlee02135's Avatar
2004 C32 ///AMG
try it out and let us know
i still havent installed my dead pedal yet
Old Oct 28, 2006 | 06:49 PM
spr's Avatar
spr
yeah I will. I'm not much of a sewer though. seems like a good idea in theory though. I think I'll see if I can find some strong thread.
Old Oct 28, 2006 | 09:42 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Replied tp your PM. The EZ Anchor that came with my Carlsson DP created a perfect system to screw into firmly. if you don't have them you can buy 2 at Home Depot for about 15 cents. Make sure you get the light duty nylon Ez Anchors for best results. Don't worry about the carpet. Its resilliant enough that if you remove the pedal later no holes will show. Remember just to go slow and easy when you screw in the EZ Anchor and just hand tighten. It should be a VERY easy and straight forward install
