Installed Wires/plugs 2day!
I Had A Few Friends Help Me For Beer And Pizza To Install My Magnecor Wires And Denso Iridium Plugs. Well Install Wasn't That Hard. It Took About Under 1.5 Hours. The Hardest Part Was Getting Both Oem Wire And Oem Plug On Right Side Of Engine.(looking At Car From Front) Once Out It Was Done. Well With New Magnecor Wires And Denso Iridium Plugs Ik20 The Car Felt A Little More Of A Sprinter But Then Again The Car Has 46k Miles On Oem Stuff And New Stuff Should Make Car Feel A Bit Better. I Recommend U Guys Save The Labor. Most Shops Would Install Which The Lowest Non Dealer I Found Was $350 Labor And The Dealer About $470 It Took Me Actually About $31 With Friends(thats That I Spent $14 On Universal Joint Which Was Used On Last Plug On Right The Hardest One). I Am Waiting On Green Filters To Arrive Then I Will Install Those Myself...........will Keep You All Posted.
P.s I Ordered A Carlab Hid Kit For My Depo Housings That Were Already On My Car. I Will Most Likely Install That Myself Too. Also Universal Joint Adapter Was Used But I Honestly Think It Could Have Not Been Necessary But We Did Use It With One Plug I Think. The Necessary Stuff Is The Long Spark Plug 5/8 Cup And 2 Small Extensions. The Oem Plugs Looked Ok Not That Bad And They Ran Fine As They Were. The Magnecor Wires Attached Nice And Snugged Also.
SPONSOR
Good Job!
Wait until you get the Pulley and ECU!
[QUOTE=AMG-Jerry;1815150]Good Job!
eventually.............I want to use up most of warranty b4 I invest that route.
