DIY Brake Rotors -Easy as pie. Question re sensors
So, the job is a cinch. I won't describe the brake pad replacement part since it's probably done elsewhere. (And changing pads involves a lot more skill and nuance than the rotors!) Once pads are out, there are two big 18mm bolts that hold the caliper to the hub, on the back of the hub. Box wrench (used 19mm - why don't they seem to make 18mm?) and a rubber mallet to pursuade, and they were off. Caliper off and resting on a box (not hanging by brake lines). The set screw for the rotor is a big torx. I only had a torx screwdriver, but put a big box wrench on the screwdriver handle. Popped loose and unscrewed easy.
Here's the only possible hang-up. One of my rotors was seriously rusted to the hub. Rubber mallet couldn't budge it, nor could hammer blows, wood blocks or a combination. Knowing that the rotor was trash anyway, I took a 25 lb iron dumbell and whacked the rotor near the edge. That did the trick.
New rotor goes on with the set screw (use blue locktite), then the caliper with the two 18mm bolts, then pads, then the wheel. I did a quick cleaning before putting on the wheel using brake cleaning spray. With all the parts and tools readily available, I think I could do a full 2-wheel brake job in 30 minutes. I wonder what a dealer would have charged me. Total cost was about $350 in parts.
Took the car out for a series of 6 or 8 hard stops to heat cycle the pads and transfer pad material to the rotor. So far, not even a squeal. I love the smell of smoking brakes!
So, what do you do with old rotors?
I still have my old rotors laying around - not sure what to do with them, I guess junk them on one of those neighborhood-pick-up-anything-and-dump-it days.
