check engine light and cat noise
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
i changed the o2 sensors on those banks and now i get these 2 codes no longer do i get the first 2 codes
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
and my ctaylic converter is making weird noises are those codes normal
Secondly, No those codes are not normal. Did you use MB OEM O2 sensors. If so, then I would check for loose connectors at the ECU.
If you want to continue on your own then I would reinstall the old O2 sensors and see if your back to original problem.
