Brake Line Flush?
08 E63
Brake Line Flush?
Need some quick advice-- my car has about 24,000 miles and needs service A. my SA says i also need a brake line flush as well. do i really need this or is it not necessary at my mileage? TIA
C55 AMG
This is relatively cheap I would think and I would do it just because it's cheap. BUt the norm to change the fluid is like 30k-40k miles. I would think it depends on where you live to as the fluid likes to absorb water and water in your system equals failure.
Two years is a maximum for brake fluid replacement. I change mine four times a year! It all depends on how how you get your fluid. For normal street driving where you never get the brakes hot for extended periods of time, one to two years is the recommended interval. For excessive brake applications, like canyon runs and track events, I would recommend at least twice a year. Every time you get brake fade, you introduce air into the system through moisture. You can change the fluid yourself and save some money in fluid cost as well by bleeding out the fluid until the bubbles are gone and toping off the resevior. Some track event participants flush new fluid into the system after each event without changing out the entire quantity of fluid. RBF600 works great for high temp outing and is reasonable in price. However, the stock fluid is pretty good and should be fine for 99% of all drivers. I run titanium backing plates between my pads and the caliper pistons to keep excessive heat out of the caliper which transfers heat to the fluid.
