Porting, Polishing, and Cams project
Old 08-31-2007, 09:25 PM
  #576
SPONSOR
sales@eurocharged.com's Avatar
C63S
OK, here are two videos from tonight. Please download them to your desktop and turn up the volume!
Again, the car feels good and screams for more. I'm happy with the ways it feels and I need to get it to the track to see how she runs there.
The video with me coming towards my buddy is 1/4 mile from where I started and I ran passed him going over 110. Granted, it's no drag strip, but it gives some insight.
http://www.renntechc32.com/movies2/
My buddy said it sounded like a formula car flying by...I should have let him drive.
Old 08-31-2007, 09:36 PM
  #577
pshek's Avatar
2003 C-Class Sportcoupe
Originally Posted by neihouma
What gives? Installed a boost guage yet?
Boost is just a measurement of restriction to air flow. Since AMG-Jerry had his heads ported and polished, there should be less restriction and less boost. So the fact that he is making less boost than stock is not surprising to me.
Old 08-31-2007, 09:43 PM
  #578
neihouma's Avatar
02 C32 AMG sold!
When he installed the LET pulleys he was making more boost over the
Renntech pullies from his datalog, 1200 miles ago.
Now he's making less boost. I'm aware when you open up compression either
from the exhaust or intake side, you'll make less boost, thanks!
Old 09-01-2007, 03:57 AM
  #579
c32used's Avatar
LET C32 2002
It sounds great.....I have to drive it one day to feel the difference....hope it took some doubts from you.
Old 09-02-2007, 12:55 PM
  #580
SPONSOR
Eurocharged Rick's Avatar
installed a set of evosport headers on the car...JGSX was nice enough to send me his brand new set of headers to try and see if the car would make more power with it breathing better...
got them installed last night and went for a drive...car definitely feels better, but i am still making too much boost...i am still at 1.5bar...
i am going to the track this afternoon to see what kind of time that the car will put down if the rain holds off...
i am going to get the car back on the dyno on tuesday if they can get me on then...they are going to try to work me in, as they are already booked for the week...i will post up some new numbers as soon as i have them...
Old 09-02-2007, 02:51 PM
  #581
c32used's Avatar
LET C32 2002
Thumbs up
Thanks JGSX! Without such participation projects like these get no-where...thanks...
Old 09-02-2007, 02:53 PM
  #582
SPONSOR
i agree! it was so generous of him to let me have them to experiment a little...
Old 09-02-2007, 03:08 PM
  #583
c32used's Avatar
LET C32 2002
What do you think about them compared to what you been told about your custom headers that are still in the building process?
Old 09-02-2007, 03:37 PM
  #584
neihouma's Avatar
02 C32 AMG sold!
That is a bold face lie, take that back!
Old 09-02-2007, 04:18 PM
  #585
SPONSOR
trust me, i wish it was...i am going to do some datalogging as soon as i get a chance...
i was going to do datalogging today at the track, but it is raining here, so i won't get to see how the car is running today...
i will let you know what the car is doing as soon as i get a chance...
Old 09-02-2007, 04:24 PM
  #586
Zeppelin's Avatar
C32
I'm a little confused.
1FASTC32 is making too much boost at 21.5psi and AMG-Jerry is not making enough boost at 17psi. How much boost are we trying for here?
Old 09-02-2007, 04:35 PM
  #587
SPONSOR
the main reason i keep saying that i am making too much boost is that i am maxing out the MAP sensor...
with this happening, along with my IAT's getting as high as they are right now, then the car keeps pulling too much timing to make significant power on the top end...
i am going to try to do a couple of things to remedy this in the short-term...
Old 09-02-2007, 04:48 PM
  #588
neihouma's Avatar
02 C32 AMG sold!
I meant that, you can never have too much boost
On a serious matter, when you data log it, what device are
you using? Are you using CarChip like me and Jerry are using?
Also what readings are you getting? I still haven't heard
from Davis the manufacture of the CarChip why the both
of us are getting high readings, and why the unit won't
read my intake manifold pressure in my 03 EVO8, and I
know I'm running 22psi on that car (or 1.5bar).
Old 09-02-2007, 05:26 PM
  #589
SPONSOR
no, i am using dynoscan, you have to datalog with a laptop with this setup...
Old 09-02-2007, 06:12 PM
  #590
Jani Anttila's Avatar
C32 T-modell
I have been watching quite closely on one CDI-engine tuning project on our local forum. As far as i understand, for CDI-engines the volume of injected fuel is decided by readings from MAP-sensor, it is not entirely up to injection mappings. Maybe it is same way for our engines. Since MAP measures pressure, not flow or volume, thats why boost really matters here and porting heads is not so good thing to do. Guys with this project also ran over their MAP with too much boost, so they build quite simple bleeding system to prevent it going into limp-mode.
Jerry´s car is running too lean, right? Maybe there is some way Jerry could make things better by doing something to his MAP so ECU will think it has more boost than it really has? By changing bigger pulley it will ofcourse get more boost and be back on the track again, but it will still run too lean because of increased volume of air. Changing heads back to stock is ofcourse best thing to do, but i would look into MAP first if there is some way to mod it.
Old 09-02-2007, 11:15 PM
  #591
SPONSOR
couple of things to address your post:
1. Jerry is not running lean anymore after fixing the spark plug gap...
2. there is no way to simulate more boost in a motor for a sensor like the MAP sensor...the only way around this would be to add more fuel earlier in the map all the way up to the point where you are at max boost...
3. there are several ways to deal with the MAP sensor seeing too much boost or being maxed out...you mentioned one, which is to bleed off boost...this is not a safe way to "tune" the car accurately in a gasoline application, you can get away with it in diesel applications because the setup is completely different, namely the combustion/burn process...i could go further into an explanation here, but i think you get the point...
4. there are some ways to fix the over-boost situation in regard to the map sensor...i am going to try some of these from my experience tuning other vehicles, hopefully the cheap fix that i have in mind will work for our application...
Old 09-03-2007, 02:17 PM
  #592
Zeppelin's Avatar
C32
Let us know if you find a fix. Sounds like the LET pulley is not a good option right now if the car cannot handle the added boost.
Old 09-03-2007, 02:29 PM
  #593
SPONSOR
C63S
Does anyone know if the MAP sensor from any other MB would work?
Is the MAP sensor really being maxed out, or is it just tripping a CEL because of the ECU and programming?
Vadim?
Old 09-03-2007, 02:35 PM
  #594
SPONSOR
C63S
OK, talked to Vadim. He will try to post tomorrow.
A higher reading MAP sensor will not work due to the ecu's map.
Old 09-03-2007, 02:41 PM
  #595
SPONSOR
C63S
Can you provide more information or links to their projects?
Old 09-04-2007, 07:08 AM
  #596
C32 T-modell
http://www.mersuforum.net/forum/viewtopic.php?t=27045
Basically they are running 200cdi with C30 AMG injectors, 320cdi turbo + lots of other extras. At the moment they are stuck at ~260hp/500Nm with torquecurve almost identical to stock. Injectors+other components in fuelsupply should be good well above 300hp, but they are still facing problems in getting enough flow through engine, some restrictions in heads/headers/cams/valvesprings etc... OEM parts are used as much as possible.
Unfortunately all information is in Finnish, but at least there is pictures & datalogging sheets which you will understand. I will try to write somekind of summary on their project in next few days.
Old 09-04-2007, 12:02 PM
  #597
msheredy's Avatar
MB
So if the maps were modified to match the new higher MAP sensor would that work then?
Old 09-04-2007, 12:35 PM
  #598
SPONSOR
C63S
I will have to let Vadim answer this one....
Old 09-04-2007, 01:12 PM
  #599
Vadim @ FD's Avatar
S600TT, R350
Stock MAP sensor can only measure 22 psi - max. After that it will trigger check engine light.
Yes, a wider range sensor can be used, but the maps will have to be rescaled, which is a major tuning project.
Old 09-04-2007, 03:26 PM
  #600
430
430's Avatar
SLK32
Outside of not running more than 22psi of max boost and not rewritting the maps are there any other solutions?
Quick Reply: Porting, Polishing, and Cams project
