HELP!! -Reduce Oil Level Message - CHange Oil Recently
So I change the oil recently, and I just got this message a few minutes ago. So I wonder:
1. How bad do I need to reduce the oil?Or how quicly??
2. Can I do that myself?
3. Or can I take it to any oil change place and have them do it?
Help!
Help!
1 Post
03' E39 M5, 10' CLS63 AMG
if u have the pump to change ur oil u can do it ur self, but if not then u need to take it into the dealer or a local shop to reduce the oil i think u'll only need to take out a little bit. but u should get this done ASAP. BTW: make sure the blow-jo shop does not crack the drain plug to reduce ur oil level.
Thanks!!! I took it to the shop, they only took less than half a quart,however they message will still appear. After leaving the car settled for like 2 hours, the oil now checks ok.
I am going to the dealer hopefully tomorrow to have it check.
Thanks again!!
Thanks again!!
