how to install camber kit????
Old Apr 13, 2007 | 02:08 PM
amgstyle's Avatar
2002 SLK 32 AMG
hey guys i just purchased a pair of front and rear kmac camber kit's, and was wondering if anybody on the forum installed it themselves. does anybody have intructions to installing them. thanks for the help.
Old Apr 13, 2007 | 03:42 PM
spr's Avatar
spr
Nice! How much did they run you front and back total??
Old Apr 14, 2007 | 04:35 AM
spr's Avatar
spr
Hey. You will need to remove the arms and have them pressed out by either a shop or if you have a press do it yourself. You will then have to have them reinstalled and realigned to your desired specs. All they are are eccentric bushings so that you can change the camber better than doing the "crash bolts" btw I did the crash bolts in the front with the EUR alignment. NICE. Let me know how it goes I was thinking about doing them a while back. I hear the ride suffers a bit however.
Old Apr 14, 2007 | 03:56 PM
amgstyle's Avatar
2002 SLK 32 AMG
do guys think i can use the mb camber bolts instead of buying the kmac kit for the front?? it would save me some money???
Old Apr 14, 2007 | 07:11 PM
spr's Avatar
spr
The camber bolts don't give you that much negative.
Old Apr 15, 2007 | 01:55 AM
smgC32's Avatar
camber bolts will only take you to an additional +- .25 degrees. My car only could achieve -1.1 with them. The KMacs provide -2.2 at full negative, and with strut shims, I was able to get to -3.1 which is too much in this car even for the track. Ride is stiffer but handling is much better and direct.
