SLK 030 Performance Package Brakes
Old May 18, 2007 | 12:51 PM
  #51
WaveyKat's Avatar
Something Slow
Originally Posted by rlee02135
yes, the fronts are bigger. they are a 6-pot 360mm kit.
meaning if the 030 REAR SLK AMG Brakes will be Bigger than the C32 AMG Front Brakes
i want to get just the SLK AMG Brakes for the rear and leave my C32 Brakes up front.
Old May 19, 2007 | 02:11 PM
  #52
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
Originally Posted by Zeppelin
With ABS how do you determine this?
good question. i'd like to know myself...........maybe the rear pads have more torque and braking than stock - for given pedal pressure? but what happens when you approach lock up? will ABS cut in to keep the rear wheel from locking up?
Sunil- i had called you earlier when thread got going for prices. how much would the slk 030 cost- for rear only? does anyone know? How much from Steve?
reason i'm asking it that i'm trying to fit wider tires in rear and would like to take advantage of the added footprint.
and what's the diff for rear brakes - between slk 55, slk 55 030 and clk63? I can't tell from the info on this thread. but i'll go over to steves' website when i'm done here.
Old May 20, 2007 | 04:24 AM
  #53
rubensans's Avatar
Brabus K3
Do you think you can fit the front ones with Brabus 18' Mono S?
No problem with the offset, but don't know the diameter.
Best Regards.
Old May 20, 2007 | 11:52 AM
  #54
rlee02135's Avatar
2004 C32 ///AMG
think they are around the same. Russel Stevens has this setup.
