Need help from techies
Old May 13, 2007 | 08:25 PM
c230_2k2's Avatar
Alabaster White C230K Grey Int. and 2003 C32 pewter/charcoal gray
My C32 got an easy entry feature, last week the seats wont move back only the steering wheel adjust. Anyway deale fixed it but now I found out My other key wont d it. Only one key works. Can I program the other key so the easy entry feature will wrk too? If I'm not mistaken te dealer replaced the seat control module. Thanks.
Old May 13, 2007 | 08:41 PM
AdaMBombC32G's Avatar
NEW 08' M6 CAB, 06' 997 911 CS CAB, 09' RX350 AWD, 10' E350 4M, 10' Range Rover; FS: 04' C32 AMG= FS
i may be wrong but i think there is a feature that makes the keys "independent" thru the steering wheel controls. basically it would enable each key to remember "individual" settings for mirrors, seats etc...
if u deselect that or turn it "off" it should work flawlessly (just about) everytime,
someone please correct me if im wrong
Old May 13, 2007 | 09:36 PM
Eurocharged Rick's Avatar
SPONSOR
BINGO! scroll through the settings menu and you will find that your vehicle is set to key dependent settings, just turn it off and enjoy...
Old May 13, 2007 | 11:28 PM
c230_2k2's Avatar
That will probably work, thanks. But what if you want that feature "key dependent"? How can you make both key work?
Old May 14, 2007 | 12:01 AM
SPONSOR
just set it that way in the setting menu for each key...
Old May 14, 2007 | 12:25 AM
c230_2k2's Avatar
Did it just now and it doesnt work. Still one key wont move the seats on entry and exit and the other will. Thanks
Old May 14, 2007 | 12:28 AM
SPONSOR
did you set it that way with each key in the on position?
Old May 14, 2007 | 12:32 AM
c230_2k2's Avatar
Yes set both keys one at a time on "on" position. One key will work the other wont.
Old May 14, 2007 | 12:36 AM
SPONSOR
hhmmm, i don't know what to tell you then...hopefully someone else will chime in...
Old May 14, 2007 | 01:15 AM
c230_2k2's Avatar
i was just looking and searching the site...found some post at W211...they had to reset the key with the seats after removing the battery or replacing the seat control module...I will try that. Thanks for the help
