5mm hubcentric spacers
Old Jun 2, 2007 | 01:29 AM
cheungster86's Avatar
02' C32 Amg
are there "true" 5mm hubcentric spacers? car nutz in seattle says they don't make them and the smallest size is 10mm. I just got my wheels on with 5mm spacers in the front butit vibrates a bit at freeway speeds.
Btw, I have been religiously reading through this forum and want to thank you guys for all the help installing all my stuff. I just got bi-xenons, clear side markers, full brabus suspension, and 19'' rims installed.
I have also been reading through many posts and almost everyone says that 275's wont fit in the rear without some kind of fender modification..but i think i found a setup that works. In fact, I have considerable room in the rear. I was driving home on the freeway with my stock amg's in the back (2 in trunk and 2 in back seat) and I only rubbed once when I hit a huge bump. I will post pics very, very soon. Thanks again .
Old Jun 3, 2007 | 02:18 PM
Zeppelin's Avatar
C32
Do you really need 5mm spacers to fit the wheels? If you can get by with a 3mm spacer then you don't need them to be hubcentric. The 3mm spacer is not thick enough to cover the part of the hub that the wheel centers on.
Old Jun 3, 2007 | 09:48 PM
02' C32 Amg
hm..i'll check that out. thanks
