Help with H&R Spring install
I have my H&R springs and on the front I can get the strut assembly out, but I can't get my spring compressor around enough coils to get slack - even tightened all the way up. I have NO idea how I'm going to get the new springs on. Is there a different kind of spring compressor I can use?... (or a trick?)
The rears are the same deal, but I feel like I can use a floor jack to compress the springs, remove some bolts, and slowly let it out enough to get the spring out and get the new one in, jack it into position, reinstall bolts.
Those fronts have me stumped.
Thanks!
Thanks!
My fronts are more like non-adjustable coil-overs - I can't get my compressor around enough coils before hitting the spring perch/hat to release/install the springs. Also the rods that run along the side hit those perches making it a major pain to deal with. Your link was informative/interesting, but only so helpful in my situation.
![](http://www.bifpowell.com/pictures/cars/c32/frontleftstrut.jpg)
Maybe I can use the car and a jack in some way?
![](http://www.bifpowell.com/pictures/cars/c32/killmyself.jpg)
it is the only way you will be able to get the springs on that i know of with those spring compressors...if you want, give me a call, i stay up late...281-787-9691
2004 C32 ///AMG
what about those clamshell compressors...will they work?
http://cgi.ebay.com/ebaymotors/McPhe...24692262QQrdZ1
1fast - ditto, many thanks for the help!
rlee - unsure, but someone did suggest those to me - 1fast gave me some tips on dealing with this, I'll report back with my results
Just remember that even if you get those off, it will be twice as difficult getting the new H&R's on. The springs will not compress evenly with just two of those compressors. You will either need more than two compressors or I would suggest taking them to a shop that has a wall mounted clamshell type.
Now I'm on 3 coils, but there is no slack at the top - seems dangerous to remove it yet at this point. Opinions?
As far as getting them back on - I'll cross that road when I come to it![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://www.bifpowell.com/pictures/cars/c32/3coils.jpg)
2004 C32 ///AMG
at that price, why not just pay them to install?
If you must do it yourself then buy another set of spring compressors and use one of them on the opposite side of those two. That's the way I did mine.
Moderator Alumni
bif, I think if you've got three coils compressed like that you should be fine to take off the hat. I had it compressed like that when I removed the spring (to remove the hat) for my coil over install. I thought it was gonna go shooting out a lil bit, but it didnt even do anything.... I had one person rotate the hat off while another person held the assembly down, just incase, but nothing happened! (We just made sure neither of us stood over the thing while we took off the hat though)
GL!
GL!
2004 C32 ///AMG
if you guys haven't bought the $36 strut tool from MB yet, this one is a bit cheaper:
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWD1V
the way you have the spring compressed is fine bif, you have unloaded it enough where it won't do anything...
"Domination through superior firepower."
Turns out the first ones I had were some girly-*** spring compressors. At the hick store they have truck stuff![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
These just fit around the hat/perch better.
![](http://www.bifpowell.com/pictures/cars/c32/girlyman.jpg)
Finally got it done - just about 20 minutes ago.
Many thanks to everyone, especially 1fast for the tips and tricks; I did everything you told me to do and it pretty much worked just like you said it would - I had some improvising variations, but otherwise about the same procedure.
Pics of this drop sometime maybe this week?...dunno, going to be extremely busy, but I'll try. Drove it around a little tonight - feels awesome, very excited to get new tires.
Thanks again 1fast!
Thanks again 1fast!
Thanks again 1fast!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Thanks again 1fast!
now enjoy the car, you have earned it...
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
