Torque Converter
Subscribe
Jul 5, 2007 | 11:07 PM
For those of you have had your torque converters changed out in conjuntion with the harsh 2-3 shift, what part number did your dealer put in???
I'm going through my dealer invoice and see a part number 211-250-03-02. I believe this is the W211 -- E55 tourque converter? Are the C32/E55 transmissions mainly the same?? My TCM was replaced as well with an update to an updated version...
I am curious as to what others have had out in since my 32 seems a little sluggish when I feel it should be downshifting under lighter acceleration after cornering and more so uphill. I have to give the gas pedal more than I think I should to get the tranny engaged into a correct gear and provide push.....
Reply 0
Jul 6, 2007 | 10:02 AM
Do the throttle reset trick and if that fixes the issue then either continue doing that or get a sprint booster and your problems should be solved.
Reply 0
Subscribe
Currently Active Users (1)
