New to C32s... Problems..
Old Jul 30, 2007 | 01:19 AM
importracr7's Avatar
89 420 SEL
Post New to C32s... Problems..
hey im pretty new to the C32... i mean i can tell you how much horsepower and torque the car has... (but who cant) i just my 95 mustang and wanted to get a real car ive been on this forum and others (not to mention autotrader) for the last few weeks and i just wanted to know if there are any common problems with the car (things to look for before buying....) i found a couple low mileage cars (about 40-50k) for just under $26,000... i have been researching between this and a 330i ZHP and obviously for the price and the power you get.... the C32 wins...
if you could help a brother out that be great...
Old Jul 30, 2007 | 09:48 AM
Fifth Ring's Avatar
C32 AMG
There are some problems common to all MB C-class including front suspension bushing failures, and seat warmers that fail.
C32 has an intercooler pump that fails regularly, but if you're creative and mechanical, you can buy and adapt a Ford Lightning pump (same model, different connectors) for about $100.
Earlier C32s have had problems with coolant leaking into the tranny fluid via the tranny cooler lines. It does not affect all C32s. It's not an expensive fix IF it has not damaged the tranny yet.
Some C32 owners have problems with "quirky" transmission function at low speed and low power - hard shifts. No real diagnosis or fix.
Overall, it's a solid car, and pretty easy to self-maintain. The cost of ownership is high if you choose to allow a dealer to perform all scheduled maintenance.
If possible, buy it from a dealer and review full service records. If you can get it Certified Pre-Owned, do it. Any warranty will help you sleep.
Old Jul 30, 2007 | 09:58 AM
jgsx's Avatar
04 C32
Unfortunately all years have the possibility of this problem. I'm an 04 and I had it.
Old Jul 30, 2007 | 11:59 AM
m3_eater's Avatar
Fifth Ring has pretty much covered the common failure points. Another not to forget is the front turn signals often need a small wiring change (TSB detailed). I just had this done myself.
Old Jul 30, 2007 | 12:20 PM
Fifth Ring's Avatar
C32 AMG
Really? So it's not just Valeo radiators ? Perversely, this makes me feel better knowing my 2002 is not the weakest piece of cr@p of all C32s!
Old Jul 30, 2007 | 12:38 PM
jgsx's Avatar
04 C32
Valeos showed up on all years.
Old Jul 30, 2007 | 12:43 PM
Fifth Ring's Avatar
C32 AMG
Excellent!!!!
