c32 transmission trouble
Old Aug 16, 2007 | 04:06 PM
pfactor's Avatar
c32 amg
did anyone have a problem with the c32 go into gear but dont shift and a p0715 code input /tubine sensor. it started after my tranny line came out of the radiator and lose fluid . i replaced fluid the car still wont shift gears thanks for any help you can give me
Old Aug 16, 2007 | 08:33 PM
Eurocharged Rick's Avatar
SPONSOR
i am taking a shot in the dark here, so please don't hold me to this...
it sounds like you ran low on fluid and did one or more of the following:
1. burned up the sensor
2. damaged the input shaft
3. put the transmission into limp mode (something that would need to be cleared with a code reader)
Old Aug 17, 2007 | 03:14 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
most likely the gearbox is in limp mode. The loss of fluid caused the box to slip which was detected and it will go into limp. clear the codes and you should be fine.
Old Aug 17, 2007 | 08:09 AM
pfactor's Avatar
c32 amg
c32 trouble
i cleared the code but it comes right back on and it still wont shift its seems like it is in limp mode and when i press s or w mode the gear selected dont change also when i put it in gear it makes a louder then normal sound.
Old Aug 17, 2007 | 01:46 PM
amgmark's Avatar
ML63
Going out on a limb with a guess... radiator fluid (glycol) in your tranny... I hope you have a warranty.. Good luck
Old Aug 17, 2007 | 05:22 PM
Jon Winter's Avatar
C32 AMG, CLK 320
We just replaced a trany and radiator for $8k.
Old Aug 17, 2007 | 05:59 PM
SPONSOR
is that why you sold the car?
Old Aug 18, 2007 | 10:15 AM
Jon Winter's Avatar
C32 AMG, CLK 320
I sold my car because I picked up a GT3 and an Audi S4.
Old Aug 18, 2007 | 10:43 AM
pfactor's Avatar
c32 amg
c32 transmission problem
any one knows where the transmission control module is located thank you
Old Aug 18, 2007 | 11:47 AM
Zeppelin's Avatar
C32
How long before you noticed the line off and how much fluid did you have to replace?
Old Aug 18, 2007 | 01:34 PM
pfactor's Avatar
c32 amg
c32 trouble
i saw the smoke pulled over noticed the line off radiator fluild every where had car flatbeded to home checked with dip stick tool was about 3 guarts low replaced fluild car but car dont shift it goes in gear but no shift and the s w mode dont change when i hit the button
Old Aug 18, 2007 | 03:33 PM
Zeppelin's Avatar
C32
Have you rechecked the fluid level since you first added the 3 quarts? It is possible that it was lower than 3 quarts and when you started the car and cycled the gear selector thru the gears it could have pumped the fluid thru the lines and valve body and now it will register low on the dipstick.
Old Sep 1, 2007 | 12:45 AM
Eurowow's Avatar
Amg C32
damm
same problem i heard from a friend.
