Brake Project Finally Completed
#54
1 Post
03' E39 M5, 10' CLS63 AMG
i highly drought they are lighter, these are Brembo brakes just with an AMG badge, and painted silver. so i dont think they will be lighter. but u never know i guess until u have it in ur hands to really measure it.
#56
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
You could be right Harry. I just can't wait to see how these look on my car. w/ my rims. I think it'll make my color matched rims stand out more...hopefully...we'll see soon enough.
#57
1 Post
for sure, u should soo do this mod, i think it will look really good with ur wheels, these brakes are sweet, and work soo well i can not even begin to tell you the feel of being able to come to a full stop before even applying the full brake pleasure, before u get the brake peddle 25% way in, the car is coming to a full stop. (from any speed) it is sooo good.
#58
BTW, I was also gonna ask, did you do the proper "brake bedding" process before your normal daily-drive braking?
#59
1 Post
ya i followed that to the T, my friend who help me install this on my car is a flesh out car guy, and has built cars in the past so he took the car out and did the brake bedding the way it should have been done. after he did that is when i read on line how to do it, and knew that he did all those steps. so ya it was a good process and a good learning experience, i honestly did not know about that. but i'm glad he did.
#60
I usually do it even after a shop has done my brakes, just to be safe. Leads to longer lasting brakes, as well as more responsive.
#61
1 Post
Yeah. Not a lot of people do know about that. And it's a shame when people get good upgrades and don't do it because a lot of times, that's when people experience problems with warped rotors.
#62
So, I did the upgrade. They look WAY smaller on my rims than on Harry's car!...LOL. I think the color match rims also make the brakes look smaller.
Still freaking awesome and the caliper is massive!
https://mbworld.org/forums/showthread.php?t=209102
#63
MBworld Guru
white and whiter
of course all are still lighter than the solid 335mm setup weight in at 29-30lbs each for just rotors.
#64
1 Post
the Brembo 6 piston 360mm brakes are the same setup as the 030. However the Brembo 4 piston 355mm brakes do have lighter rotors at 5lbs lighter per rotor. The 355mm GT rotor weight in at around 15-16lbs. The 030/6 piston rotors weight in at around 21-22lbs.
#65
MBworld Guru
white and whiter
kicker in the *** is Brembo does not sell the HAT for the rotors. they only sell the replacement rotor that goes onto the HAT you already has from the Brembo GT kit. From looking at my rotors and the 030 rotors, they use different HAT.
#66
The Brembo GT kits use a different hat, rotor and caliper than the MB/AMG parts. If you get the 6 piston monoblock the the bridge is integral so the pads are split in two. If its the 4 piston kit it uses an F40 caliper (non monoblock)
#68
Look at post 1001+ of my thread. I have pics of mine when they first went on:
https://mbworld.org/forums/showthrea...103716&page=20
