How Much Is It To Replace All Brake Pads 2006 C55
There are plenty of other brake pads that you could get for cheaper prices, but I've heard lots of good things on the forum about the ones I chose. You can find the akebono pads on tirerack.com and the porterfield pads I found at formymercedes.com.
Don't be scared to search, there's lots of valuable info on both c-class forums.
I kicked myself after I found out it's no different than any other car.
I would definitely do it yourself, replace the lines with stainless, replace the fluid with motul 600, and use a better pad. I would use a pagid blue 4-2-1 sport S pad, or potterfiled rs4, but it seems like the akebonos might be good, although I have zero experience with ceramic pads and cannot comment with first hadn knowledge.
You might want to take it to the dealer with some extra motul 600 and have them rebleed it as I know with my 911 they have to use a machine to open up the abs to completely flush and remove the air in that circuit when I did the 14" kit.
