Need helP making decision with 19's
Old Nov 1, 2002 | 09:01 PM
pc527's Avatar
2005 B6 S4
picture 1
Old Nov 1, 2002 | 09:02 PM
pc527's Avatar
2005 B6 S4
picture 2
Old Nov 1, 2002 | 09:03 PM
pc527's Avatar
2005 B6 S4
picture 3
Old Nov 1, 2002 | 09:04 PM
pc527's Avatar
2005 B6 S4
picture 4
Old Nov 1, 2002 | 09:46 PM
tango's Avatar
Originally posted by JustinTRW
I vote for #13 without even seeing how they look, but I venture that they are the most expensive on the list.
anyone got pics of this badboy?
Old Nov 1, 2002 | 09:48 PM
pc527's Avatar
2005 B6 S4
Here's the work that was done in the back to prevent rub.
as you can see from the pix, the edge of that piece was shaved off.
instead of rolling the fender since it was already rolled, the tech used a rubber hammer and tapped the rolled part gently to make the lip thinner. i'm not sure if this did any good but what do i know i just left it to the tech to decide what needs to be done.
there's the thin spacer i was talking about. i confirmed that was a 3mm spacer that was put in the front to clear the caliper. so i guess the offset is not way off.
the back did not need spacers.
that screw was removed and replaced with another screw with a flatter head. this is located towards the back of the wheel well.
it's pretty easy to spot.
hope this answer the questions you guys had regarding the fender work.
peter
