Thinking of getting a C32. What's the maintenance schedule like?
Compared to my friends' M3's, this car has cost me way less in repairs and downtime. We do have the extended warranty from back in 02 so that eases any concerns now. I'll probably keep the car through 09 when it's up since it has been pretty good. Plus I only just hit 36k mileage so it should be fine.
I like what you said about the weaknesses being well documented in this forum. I feel like as long as the weaknesses are small (i.e. replace some components) and can be dealt with by myself (i.e. no major transmission/engine overhal problems), the maintenance costs shouldn't be crazy.
On a side note, I was discussing this w/ my mechanic today and he said MB are have less problems than BMWs.
From the sounds of it, many of you love your C32 as long as it's under extended warranty. Do you guys plan on selling your C32 once warranty is over? I ask because the one's I've been looking at are nearing the end of their warranty.
I lean towards the C32 because it's an automatic. After driving manual all these years, it'd be a nice change. I also love the way it looks. My friend a few years back owned a C320. By simply lowering it and getting rims, the car just looked amazing.
The bad -- it isn't a very reliable car and very expensive to fix. I've owned my 36k mile '02 since March and it has probably racked up at least $2,500 in repair bills -- all covered under the CPO warranty. Whew! I wouldn't buy this car without a W, seriously. I can't stress that enough. I intend to extend mine as long as humanly possible. Also gas mileage isn't great. Mine gets between 15.5-17 MPG depending on how I drive.
'02s are the most common but the hardest to buy as a CPO with the MB warranty now. They're getting too old. I'd get as new of one as I could afford, and again be sure you get a warranty, preferably the MB warranty. There's a lot of fly-by-night warranty companies out there so do your homework if you have to go aftermarket.
Good luck!
Some people seem to have less problems with the C32 than others. One should consider buying the newest model 2004 C32s, if they are in the market. The 2002 models did seem to have a few extra problems.
For now, the C32, has been pretty good to me. I may update the battery, to preclude sudden failure (it is over 5 years old, now).
Girlfriend? Coming from a guy with that avatar, perhaps you should take your own advice. And its cute, right after I make fun of you for putting me in your sig you go and change it. Grow a backbone.
And perhaps respond once your ********* drop, or after you get out of your teens.
the one BIG thing with 02's- GLYCOL CONTAMINATED TRANNY. seach "glycol" for lowdown. I would not get an 02 unless it passes tranny fluid testing. and righ after you get it- change the rad if it's the valeo.
i've done 67k in mine...the seat heater failed 2x, the battery failed, the alternator failed (may have been related to the defective battery). rear bulb relay. thrust arm bushings. and that's it. i replaced the rad, the ic pump on my own before probs and as part of mods.
my car has 72k (bought starmarked at 5k) and runs very well for age and use, no rattles creaks (save my urethane camber bushings!)
i know you don't want to mod but -if you can -test drive a stg 2 car, i'm sure you will be impressed.
. Now you are calling everyone on the board "clueless"? Have we collectively offended you in some way?As someone that has not yet achieved "Member" status, you are alienating a lot of people right now.
You seem to like to push people's buttons. Comments like "the C32 is a piece of junk" on a C32/C55 forum is just retarded. Changing your avatar to the gay thing is certainly making friends fast.
Hell, you are even taking satisfaction in offending an entire state.You know, most of us seem to get along just fine here. There is a wealth of knowledge that exists in the minds of the board members here. Let's hope that someday, you won't need to tap into it. You may be hearing crickets in response.
edit: thanks for dropping the negativity from your profile and signature now.
