Arm rest problem
With regards to the wipe down, I had a similar scare when I used a damp rag to remove the layer of gook that had built up over the years. I thought I had lost the arm rest. It did dry out but I did not see it peel off, luckily. I have heard stories of this and I believe it is NOT covered by warranty. It is considered a wear item, unless you get a great SA that can spin the defect with MBUSA for you.
Good luck.
