Magnecore wires / rough idle
Before/mods:
Car had a great idle
Resonator delete
knn filters
Exact work done:
Replaced stock wires with magnecore wires
spark plugs were left alone
coil packs were left alone
Situation:
Rough idle
idle speed variance (occasionally hops up over 900rpms and drops down to near stalling)
sputtering sounds
noticable misfire felt inside the car
Things i checked:
-Made sure magnecore wires clip onto spark plugs correctly
-sprayed water on the wires to see if they are arcing (they are not)
-put stock wires back in (and car idled fine again)
Heres the question- Is there possibly something i missed while doing this install? can any other connections possibly be loose with the magnecore wires? Do i need to step down to a colder plug with these? does plug gap have to be adjusted with these to maintain idle? Are the wires possibly just faulty?
anyone's experience will help cuz this is pissing me off
(btw, im doing a before and after with every single mod on my car to date, which i am hoping to compile after i fix this and install a couple more parts... thanks to SPRacing for letting me use their dyno for free!)
Before/mods:
Resonator delete
knn filters
Exact work done:
Situation:
Rough idle
sputtering sounds
Things i checked:
I got rid of my Magenecore wires because of the issues I had. I'm now using the LET Motorsports plug wires. They are truely much better.
http://www.letmotorsports.com/c32.as...2&category=all
Regards,
Marc
I also hate the fact that i dont know of a way to get a reading from the knock sensor on this thing (if you know of one... please tell me!)
this leads me to assume that 2 or more of the wires are bad, but only 1 of 2 on the cylinder based on the fact that it still runs
i guess ill give magnecore a call tomorrow and try to get another set
any more ideas? should i try swapping the plugs?
i actually just thought of doing that today while i was at the shop... however it did not solve my problem
I wanted to that this morning & on top of that, run the car with 11 Magnecor
installed properly and the 12th one incorrectly to see if I can simulate the
problem or set off the CE light.
Any additional information on the plug wires? How do these compare to the EVO wires? How do they compare to the stock wires? What makes these wires better? $315 is kind of pricey for plug wires.
I am not knocking these wires at all I am just looking for some additional info.
The LET wires and the EVO wires are exactly the same! They come from the same manufacturer. LET has them for $50 less (LET includes shipping).
Here is the technical description from the brochure.
"LET Ignition Wires create the most powerful spark possible. Our wires are engineered with a special built-in capacitor. This revolutionary design allows energy from the ignition coil to accumulate in the capacitor until the voltage at the spark plug electrodes reaches the ionization point. At that split second point the entire power of the stored spark is discharged at once, creating a spark 300 times more powerful. The result is faster, more complete combustion, and most importantly, MORE HORSEPOWER that's 100%. Smog Legal."
thos are nice wires!
look just like OEM.
its well known around here how I feel about aftermarket wires.. starts with the letter M
i suffered for about 1 year with a rough idle, CEL's and poor MPG and it turned to be the wires.
I would not change the wires.. unless you buy the ones above.
don't even bother with the spark plugs either, unless you really need them.
Just spend your money on a pulley, a good IC pump and IC HE.. that is where you will see the most bang for your $$
i tried the wires, plugs, filters, ect.. its not really worth it.
quick question, i changed my plugs a about 6 months ago and started shortly afterwards having a "rough idle" searched and talked to a few members on here about the problem and not really being able to really isolate the problem... went down the route of putting new things on the car that didn't need to be replaced... but now that i've read this post... could it be that i damaged my OEM wires when i changed my plugs? b/c every now and again i'll get a check engine light popping up of Cylinder misfire (p0300 or p0301, p0302,p0303) which is either multiple cylinder misfires or just an single misfire... b/c when i try and think back on it i did have one HELL of a time trying to pull off the wires to get to the plugs......... and to add to it i was thinking about getting the Magnacore's but kind of worried i'll be having them burn a hole in my pocket... b/c i know if i replace the OEM wires... i should just but the LET/EVO wires for about the same costs...
Sorry bro, it sounds like a bad wire. My idle has improved since the LET wires were put on and I have cams and a long history of idle issues.
