question
Old Dec 3, 2007 | 07:19 PM
asdfijl's Avatar
2007 c230
question
alright fellas, pardon my lack of knowledge of mods and whatnot, but i have seen quite a few c32's with what seems to be foil-like wrap over the tubes of the intakes. anyone know what it is? im super curious i have a pic here....
Old Dec 3, 2007 | 08:04 PM
Bif powell's Avatar
2002 c32
Closer pic would help to determine quality, but it looks like someone just trying something to overcome the heat-soak from these cars. On hot days (and some not-so-hot days) you can loose some power due to how hot that s/c gets. I've noticed it myself on Autox, but I gotta imagine on the road-course you have more air going over the engine and that helps?...Fifth will jump in here on that, but to your point, pretty sure that's what the guy was trying to deal with.
Old Dec 3, 2007 | 09:32 PM
asdfijl's Avatar
2007 c230
hm, i see. yeah i've noticed this on a lot of c32's. is the power loss on hotter days a common issue?
Old Dec 3, 2007 | 11:27 PM
calimax's Avatar
RENNtech C32 AMG
Those wraps are a joke. I wouldn't be so worried with the engine compartment's ambient air producing too much heat soak through the intake, as I would be more with the super charger doing so. That loss of performance that we notice (given the I/C pump works) is the ECU pulling timing to reduce the possibility of knock/detonation. In more simple words, the computer makes your car have less HP so you don't blow up the motor if its sucking in too much hot air. Things like Nitrous or a Methanol/Water injection system help keep the intake temps down and give a boost in performance!
