C55 threw the belt
I nursed it home, opened the hood, and found the belt lying flat just below the pullies. It looks perfect - no cuts, no rubs, nothing. The car is an 06, about 18 months old with 14k miles. Has anyone else been through this? What seems like probable causes? Stretched belt? Bad tensioner? Bad pulley or failing pulley bearing? I'm about to go put the belt back on but don't know whether this was a fluke or whether I'll just be shedding it again tomorrow.
Anyone else had this failure?
Same thing happened to me but I thought it was because of my supercharger. I had to change the tensioner pulley that cost a few hundred bucks. In my case, the belt shredded instead of shedded. Before this incident, I noticed that when I depressed the acclerator hard sometimes the rpm would shoot up to redline but the car did not speed up much. This turned out to be signs of the belt starting to slip. Did you have such symptoms before the belt came off entirely?
I've lost an idler pulley once before in the supercharged Pontiac V6 I once had. The bearings apparently got hot and the plastic pulley couldn't handle it. It was common for users to replace that pulley with a metal one, and GM eventually began stocking metal replacements at the dealers. Are any of our pullies plastic?
