*** VRP Project X55 ***
#135
1 Post
not stock.
if you read the other posts the same has already been said and the same has already been answered... getting a C55 could probably be a cheaper alternative depending on your intentions with the car... its like what the owner of iforged did with his 996TT .... everyone said that getting a 997 would have been cheaper ... well, with what he was after..it actually made more sense to do what he did..
#136
2015 E250D
after doing all the modifications to my car prior to the engine swap, it did not make sense to me to get a c55. I did not want to go through the trouble of swapping everything out of the c320 into a c55.
#138
#144
1 Post
not stock.
I can only imagine this thing with a fully modded engine... pulleys, intakes, IC pump, Heat exchanger, TUNE ... LSD, Id do a slight widebody / fender pull in the rear to fit 285 rubber... i think its justifiable hahaha
#147
isn't the w203 body lighter then the w211? if that's true then it should be slightly faster stock on stock
#149
