Planning on switching to this oil...
Old Jan 4, 2008 | 03:12 AM
c32used's Avatar
LET C32 2002
Royal Purple prior to Drag strip season 2008 what you think and what thickness will work best for 80% daily driving and 5% AutoX 15% drag strip?
Old Jan 4, 2008 | 03:55 AM
C32ken's Avatar
04 C32 Silver
i would not use royal purple. MB approves 229.3 or 229.5 oils and RP does not meet this requirement.
read your manual, it specifies there what oils are approved that meets 229.3 or 229.5 certification.
i actually use elf Excellium in my Audi and so far it is better than mobil1. i will be using elf in the C32 on the next oil change.
check out my friend's site... http://lubrify.com/elf-synthetic-oil
if you wanna order, let him know i sent you... he will give you some discount.
Old Jan 4, 2008 | 03:03 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I would not use Royal Purple on the track right away. Start slowly on the street and see how the car is performing with it, then slowly increase load to maybe track level. I'm still using Mobile 1, but I'll be in a very similar position as you're in when it is time for my next oil change
Old Jan 4, 2008 | 05:07 PM
john89011's Avatar
MB C32 AMG
I don't know if it's a good idea to switch oils if you already used something else. Don't know just my 2 cents
Old Jan 4, 2008 | 05:51 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
may I suggest Liqui Moly to you all. I've been switching from mobil1 and liqui moly every other change.
Old Jan 4, 2008 | 06:46 PM
C32ken's Avatar
04 C32 Silver
Liqui Moly is good stuff. also passes MB 229.x
http://lubrify.com/liqui-moly-additives/
Old Jan 5, 2008 | 12:49 AM
c32used's Avatar
LET C32 2002
I think I will research that Liquimoly stuff...
