Adding options to C32
Old Jan 20, 2008 | 05:55 PM
moosejaw's Avatar
none
Hell no! I watched 04blackc32 wrestle with my bumper to get these in
Old Jan 20, 2008 | 06:18 PM
dkflipse's Avatar
C32 AMG
That's funny. Is the fitment 100% like factory?
Old Jan 20, 2008 | 06:20 PM
moosejaw's Avatar
none
you would have to ask ernie, there wasnt enough room under the fender for both of our heads. All i know he was cursing when he came across the washer reservior on the driver side.
Old Jan 20, 2008 | 06:25 PM
dkflipse's Avatar
C32 AMG
Yeah you need to find yourself a petite mechanic. Ernie is built like a linebacker!
Post some pics wit all lights on
Old Jan 20, 2008 | 08:32 PM
04blackc32's Avatar
2004 c32, 91 GMC SYCLONE AND AN 08 CBR 600RR(MAN THIS THING IS FAST)
i might be a linebacker but i got them in lol. and yes they are really straight forward and fit just like stock.in the driver side its tight beacse of the washer but not to bad once you losen the waaher.
Old Jan 20, 2008 | 08:34 PM
04blackc32's Avatar
they go in 100% like factory
Old Jan 20, 2008 | 09:22 PM
  #32
moosejaw's Avatar
none
ernie one more post you are at 100!
Old Jan 20, 2008 | 09:30 PM
  #33
c55asleep?'s Avatar
Bicycle
Originally Posted by moosejaw
I took some more pics while shopping at Home Depot
Drew, lights look really good.
Old Jan 21, 2008 | 12:18 AM
  #34
c32used's Avatar
LET C32 2002
Looks REALLY nice and OEM! I put a bid on the cheaper ones wish me luck!
Old Feb 7, 2008 | 02:21 AM
  #35
t1n0's Avatar
Black on Black stock ' 03 C32
Originally Posted by c55asleep?
I see you put that it only works manually. Try going to each window and holding the button all the way up for a few seconds then all the way down. Do that to all the window to activate the auotmatic features. Then repeat the remote feature from outside the car. Maybe b/f you purchased the car the battery was disconnected? Its just a past problem i ran into.
Thanks.
I tried, but nothing.
I did the up/down for each from the driver console, and I also did the cycle from each door too. Still nothing.
I think I will have to go to the dealer. I have a few other annoyances that the place I bought from were clueless about.
Thanks for the invite. I had not subscribed to the thread, so I had not received notices about the replies above, and consequently I missed the meetings you guys had for this month. My mistake, I thought thread subscription was automatice like other forum/sites.
I'd like to meet up next one, please let me know. Myself being completely new to this car, you guys would be a great help about features and reputable mechanics in south florida.
TIA
T
Old Nov 9, 2008 | 07:40 PM
  #36
t1n0's Avatar
Still haven't gotten the windows to work..
Are you guys still meeting? Where/when is the next one? According to the systems/schedule posted above I think I missed it until next month, because it states the first Friday and first Sunday..
If there is another one earlier than december, please let me know.
BTW I found a good mechanic. Down on 117 and 120 in Kendall. Quick and reasonable.
Old Nov 9, 2008 | 11:49 PM
  #37
WaveyKat's Avatar
Something Slow
you can get the Sensor in the Door handle Replace!
Old Nov 10, 2008 | 02:16 AM
  #38
moosejaw's Avatar
none
Where u at in North miami
I am in Aventura
Old Nov 10, 2008 | 10:51 PM
  #39
redfarsi's Avatar
04' C32 AMG & 90' TT 300ZX
Originally Posted by t1n0
Hello all. This is my first post, evah.
I just purchased an '03 C32 this week, so I am new to this.
I was wondering about the feature that allows you to rol down all fours windows and open the sunroof from outside the car. It is supposed be triggered by holding the unlock button for about three seconds while aiming the FOB at the driver's door handle.
Mine does not work.
What this feature called?
Was it an option or standard equipment on the '03 C32?
If my car does not have it, can it be added? (I'm in south Florida, and it would be really nice to have)
I apologize if this has been covered. I tried searching for it several different ways, but I could not find it.
Thanks in advance,
T
Looks like this thread has completely went off topic. I have looked into this earlier and if you used the search function you would have been greeted with results. Anyways it will work on your car you just need to program the key to do it. You can do all windows or some windows or just sunroof. Whatever combination you want. Its all in the manual if you read through it.
On page 202 to be exact.
Old Nov 10, 2008 | 11:05 PM
  #40
c32used's Avatar
LET C32 2002
Question
Well people like me don't have the manual...could you please post what to do as well as the thing you programmed my key to do that permits the drivers door lock to open while others are closed..
Old Nov 10, 2008 | 11:54 PM
  #41
1qikctr's Avatar
Merc power
Reason some of you having trouble with this function, b/c your battery might be low. It happen to me B4, my battery was low so it did not have enought power to Lower the window and sunroof, also so, make sure your remote battery isn't low.
Old Nov 11, 2008 | 02:59 AM
  #42
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
have a manual and rarely use it. the thing's next to useless other than few times I need to remind myself how to reset the Homelink. Can't even find instructions on how to remove the trunk light cover and replace the bulb.
to change the program on the key just 'press and hold unlock & lock at the same time' for 5-10 second till the little light on the key blinks.
Old Nov 11, 2008 | 02:49 PM
  #43
t1n0's Avatar
Ok, Ihad replaced the battery with two fresh ones, and I had tried the up and down cycle on each window, will try this...thanks for the info.
Old Nov 13, 2008 | 12:50 AM
  #44
t1n0's Avatar
The 'programming" in the manual let's you choose between single, driver's side door unlock, or "Global" unlock which opens all doors with one button.
I have tried everything mentioned here regarding the summer feature that rolls down all windows and opens the sunroof when you hold down the unlock button while pointing towards the drivers door handle.
It simply won't work. I thank you all for your suggestions.
I notice in the manual it has a star (*) next to the instructions, and states ' ...some equipment optional.."
Could it be possible I simply don't have that option on my car?
That would suck...who in the world would delete that feature to save a few bucks?
My only dreaded option is to go to the dealer. That's not going to happen anytime soon; good thing it's winter in the northern hemisphere.
