ESP program not available after battery swap
Old Jan 31, 2008 | 01:09 AM
shocker21's Avatar
2005 C320
O.K. here it is:
Battery completely died, charged it enough to start and drove to work, had to jump it at work to get home, replaced it tonight(new from MB), start car(02 c32), then I get an ESP program is not available malfunction.
I haven't tried driving it yet just started her up a couple of times and the problem still persists. Any help would be appreciated, thanks
Well I decided to not wait till the morning to drive it and esp works on and in the off mode, got home and turned off the car and back on agian and the malfunction is gone, but some residuals are still here. Now my sun roof will only open in 2" increments but closes fine. I will tilt open but it takes pushing the close tilt 2 times to get it to come down.
Old Jan 31, 2008 | 01:30 AM
cnchung's Avatar
C32
I had a dead battery lately, jump started it, "ESP prog not available" on. Drove it for half an hour, shut down, went for a coffee, restarted it, and things got back to normal.
Go ask the shop to check the ECU for faults. You need ESP for C32, wheels spin easily.
Old Jan 31, 2008 | 08:59 AM
shocker21's Avatar
2005 C320
You didn't have any problem with your one touch windows and sun roof?
My windows didn't work at first along with my roof but now it is just the roof.
Old Jan 31, 2008 | 09:28 AM
john89011's Avatar
MB C32 AMG
You'll get that after a battery swap. Just drive the car for a while and next time you start up the car the message won't be there.
Old Jan 31, 2008 | 09:48 AM
jacek9478's Avatar
C32 AMG
Originally Posted by shocker21
O.K. here it is:
Two things that must be done after replacing battery:
1. ESP- start the engine, turn stearing wheel all the way to the left and than to the right- calibrates stearing angle sensor.
2. windows and sun roof- open each window, than close and hold up botton for 5 seconds- programs one touch feature.
Regards
Jack
Old Jan 31, 2008 | 10:16 AM
c32used's Avatar
LET C32 2002
Regards
Jack
+1
I was about to write the same thing...
Old Jan 31, 2008 | 12:10 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
that's the first system that goes as voltage drops (don't ask me how I know)
just drive the car it will go away as battery charges up.
