tranny jerking... try this solution
Old Nov 24, 2002 | 04:14 AM
c32brabus's Avatar
i used to have this prob with my 2002. Try this solution im sure it will help not only with the tranny but also with the overall performance of the car. Once you feel that your new c32 has been broken in (around 10000miles after first oil change) reset the ECU. You can do this simply by disconnecting you battery for about half and hour to an hour. It take about that long to get rid of all the info you c32 has learned so far. once you reconnect the battery then it will start to adjust and learn without any buggs.
dont be allarmed if:
your traction control light stays on for a few miles, it will go away after that and also, your one touch window switched have to be reset. to do this pull the window down all the way then pull it up and hold the switch for a couple of seconds untill you hear a light clicking sound this means its set. do this with all the windows and the sunroof too.
by the way my car is for sale if anyone is interrested
www.msnusers.com/mercedesbenzc32amg
Old Nov 24, 2002 | 03:58 PM
dfc's Avatar
dfc
03' C32, 98' Civic EX
You are so high-tech dude. How did you figure all those little tricks out? Thanks for the hints, I'll need em' when my car reaches 10k. Oh, by the way, when you got the 19's, did you have to do anything else to make the rims fit? Say, spacer, fender roll, etc.
Old Nov 24, 2002 | 09:50 PM
c32brabus's Avatar
if you order the original brabus wheels they come with spacers, you need to put the front ones on but for the rear ones you cant use the ones they supply u with because they will rub. find 1/8" or 1/4" ones for the rear. then you can fit twenty people in the back and they still wont rub.
by the way i have the H&R cup kit on the car also... still never hear a squeek from the tires.
