Two-Piece, True Floating, stock replacement rotors are here...
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
Looking for those for months!!!!!!!!
I'm on the market for a pair of floating rotors for the c32 brakes, when are you planing to start shipping it?
Me and my friends on the MB Portuguese forum are waiting for prices
I want to debate one subject with you guys,
I've been told that for our front brake system using lighter rotors won't be good, because of the power of the caliper, and thats why the stock rotors sucks!
I noticed another thing, brembo stock rotors replacement are also heavier than the OEM!!
So, lighter weight is better!? I always thinked so, but for this brake system now I'm confused, I was searching for lighter and better rotors from months...
PS: who told me that was an person who works in the brakes area...
#32
#34
a quarter mile at a time
#36
One piece rotors are obviously the worst, they are heavy and are more likely to warp under extreme conditions.
#37
2008 A8L, 2002 996TT X50, 2009 X5
e1000,
your reply to my post was an excellent explanation to my question. As I read it, gaiex is asking a completely different question "will going to a considerably lighter rotor somehow be a mismatch with the factory caliper?" - my guess is no, but I'm certainly no expert to answer it.
#38
e1000,
#39
PICS!!!!!!!!!!!
Partial (Semi) Floating rotors - notice the spring mechanism:
![](http://www.zeckhausen.com/Brembo/Screws_installed_700pix.JPG)
The Code3 rotors above are a full-floating design and you can see how they do not have the spring.
#40
04' C32 AMG & 90' TT 300ZX
what advantage does a 2 piece system have other then being cheaper to produce and being lighter? Could we expect these to come in drilled and slotted as well?
Thanks!
ps. great product!
Thanks!
ps. great product!
#42
For example, a set of stock OEM C32 1-piece front cross-drilled rotors can be purchased for about $240, give or take. These 2-piece C3P rotors are going to run somewhere around (i.e. under) $800 for a front set, according to Brandon. Which, incidentally, is a steal vs. upgrading to a BBK w/ 2-piece rotors.
Final point - if you read Brandon's first post, he clearly mentions that the picture is the prototype and the production rotors will be slotted, with a black (anodized, presumably) hat.
#43
Yes I read the part about the black hat, but I obviously missed the point about the slotting. I guess I was wrong on this one. Thanks for taking the time to clarify it for me c32AMG-DTM.
#44
C32, Cobra, 700hp Vespa
Just an update. The rotors will be available in either slotted, or slotted/drilled. They are about 6 weeks out now.
#47
Former Vendor of MBWorld
C55,SL55,C63
I want them. are you running any kinds of real world tests on them? if so can we maybe see a video stop from 60-0 or something like that on a benz? Maybe see a video of how these rotors out preform OEM?
#48
For a single stop you won't see any difference. The limiting factor for our brakes is the grip that the front tires can provide. The difference between these rotors and a 1 piece rotor is that under heavy use they won't warp as easily AND, due to lighter weight, ride comfort may improve.
#49
Just adding to this - removing rotating unsprung mass has all sorts of performance advantages, you theoretically should see shorter braking, quicker accelleration, and better directional changes (i.e. sharper handling). Physics is physics. If these are sufficient enough to be measurable differences from stock 1-piece, it'd have to be tested to see - but all those characteristics should get better, just like if you added a wheel/tire package that's lighter than stock.
