MP3 playing ability debate. Fact or myth...?
My 06 w/COMAND plays MP3 cd's in the single disc and the changer. Single disc allows you to browse by folders, changer does not.
If you want to PM me I would be willing to mail you my disk to see if it works in your unit.
Best of luck....
Thanks again!
Car is also equipped with the "Logic 7" system and Sirius.
The changer plays MP3's that I have burned long ago simply by copying them to the disc and hitting "burn disc". I use(d) a Mac Powerbook to do this but no special software. The disc is slammed full of data with no room left on it.
The aux in plug also works with my ipod but, of course, doesn't show the tracks and COMAND does not control the ipod in this configuration. The track information for the MP3's does appear though.
even with the CD-Changer that CAN read mp3 CD's, the Audio-20 head unit isn't able to process anything other than a normal CD. The CD-Changer is what is fooling the head unit to think it's a normal audio CD. That's why you're limited to 99 mp3's.
even with the CD-Changer that CAN read mp3 CD's, the Audio-20 head unit isn't able to process anything other than a normal CD. The CD-Changer is what is fooling the head unit to think it's a normal audio CD. That's why you're limited to mp3's.
I purchased a different CD Changer, model # 3520, and it solved the problem. My C55 was built in 12/04, and it came with the model # 3330 CD changer, which would not recognize or play MP3 CD's.
Today I installed the model 3520 changer, and it works beautifully. I now can play MP3 CD's with no problem, and the Comand head unit will read and display the file names from the disc.
The swap took approximately 10 minutes, simply by removing 1 torx screw and sliding the unit out. Very simple! Disconnect the 2 plugs on the back, then reconnect to the new unit and you're done.
I found this newer CDC on ebay, and only paid $125 for it. It came out of a 2006 C-class W203. Do a search for "Mercedes CD Changer, 2006, W203" on ebay and you should find several. Simply make sure it's model # 3520.
I appreciate everyone's input and offers to help along the way. Now we have a definitive answer on how to resolve this issue.
don't thank me, thank benze-ply he definitely solved the mystery behind what was going on. Glad things worked out for you!!!!!!!!!PS - you can probably still sell your old changer for $125 on ebay!
