Speaker adaptors/spacers needed!
detach the harness and it should pop out. I believe the speaker is held in there with 3 screws. once you unscrew them, the speaker should pop out. Then any 6.5'' speaker should fit, but the holes won't line up. Your going to need to redrill the holes into the spacer.
then reattach the spacer using the stock torex screws, it should fit like stock.
i would imagine the rears would be the same.
You can see a picture of the speaker and spacer on page 4 of the pdf you used to remove the door panel.
i would recommend using the stock spacers. If you generic spacers your going to need to redrill holes into the door panel, which would take forever.
