questions about tire size
Old Dec 8, 2002 | 04:07 PM
ning's Avatar
c32 & 330i
Question questions about tire size
Hey guys,
I am wondering what is the max. width of tire size on c32 stock wheels? I called tirerack and they told me that by changing the width will mess up the computer? is it true?
thanks
Old Dec 8, 2002 | 06:02 PM
Torque's Avatar
Porsche 996Turbo, X5 4.6, Mini Cooper, C32 AMG
Smile
Hey Ning,
You can go up to 265 and 19 inch if the offset is correct, but you have to understand that changing the width of the tires will change the way sensor work for your ESP system. The sensor that detect slip angle are design to stock tires size. You will have to reprograme your ESP to ensure the system is working properly.
Changing the width of your tires will also decrease handling charcterisitc. wider tires will provide more grip but less 'road feel' and in turn a worse handling.
If you want to change your size for aesthetic reason, then that will be a totally different story Hope this help
Old Dec 8, 2002 | 07:07 PM
ning's Avatar
c32 & 330i
Thanks..
I will call u on Monday
Old Dec 8, 2002 | 09:47 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i have a question too.
can our front stock double-spoke rims fit tire with 235 width?...if so what should the correct tire size be? thx
