VALENTINE 1 question. E message?
Old May 7, 2008 | 04:32 PM
AdaMBombC32G's Avatar
NEW 08' M6 CAB, 06' 997 911 CS CAB, 09' RX350 AWD, 10' E350 4M, 10' Range Rover; FS: 04' C32 AMG= FS
hey guys,
I've had my V1 for more then 2 maybe even 3 years now. anyway, it sits on top of the rear-view mirror (in my '04 C32) and is hardwired (where to im not sure)
anyway recently when i turn the device on (or the car for that matter) it reads "E" and under that it has a few led lights that stay on (ill try to post a pic soon)... somedays more other days less... any ideas?
i went to v1.com and they said something about a fuse. but its not soft-wired so how can that be?
ANY KNOWLEDGE WOULD BE MOST APPRECIATED, THANKS
Old May 10, 2008 | 01:31 AM
C32-4ME's Avatar
02' C32 - 07' H2 - 07' BMW K1200R
Originally Posted by AdaMBombC32G
hey guys,
Note on fuse: There should still be a fuse mounted in-line even if it is hard wired. If the fuse was blown, the detector would do nothing (no power). You may want to check to make sure a fuse was installed - it is a pretty expensive piece of equipment to not have protected by a 25 cent fuse
E on display
When the V1 is turned on it goes through a self-test / tuning mode. Anytime the V1's self-calibration routine is unhappy with how it tuned itself, it displays an "E" on the display
It could be a sign of drifting/component failure, but the 3.851's had some bugs with the E feature that caused it to be thrown erroneously.
Valentine 1 has some of the BEST customer service- give them a call and send it in for repairs if they think it needs it.
You can read much more about it here:
http://www.radardetector.net/viewtop...ighlight=error
Hope this helps!
Old May 10, 2008 | 07:01 PM
Newzchspy's Avatar
PLAID
V1 Customer Service
Boy , you got that right. Mike truly does take care of his customers.
Glenn
Old May 13, 2008 | 03:29 PM
thanks for the help guys, will 1st try to see if i can locate this 25cent fuse and replace it myself, otherwise i will be calling V1 soon for a fix and update if needed
