lowering the beast
Old Jul 6, 2008 | 07:52 PM
c32 dan's Avatar
c32 amg
lowering the beast
hi,will be gettin a set of 19"(as soon as i decide which ones to get)would like to lower the beast a bit as i seen a few c32s with 19"on stock suspension riding a bit too high..,im looking for both handling and looks but i dont have the dosh for a coilover kit so its got to be a set of springs,what do you reccommend,as i say before i want good handling(dont want to be bouncing everywhere)and a bit lower in ride height then the stock suspension...thinking of
1 renntech
2 h&r
3 brabus
4 kw
or anyother manufacturers you lot suggest??
Old Jul 6, 2008 | 08:07 PM
AirFrcd's Avatar
03 c32
Bilstein PSS 9 Coilovers
https://mbworld.org/forums/showthrea...light=bilstein
Old Jul 6, 2008 | 11:49 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Uh read his post, he said he doesn't have the dough for full coilovers. Anyways, from what I have heard, it seems like the H&R's are pretty good. Hopefully others can chime in or you could just run a search here.
Old Jul 7, 2008 | 06:07 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
renntech's discontinued, so you'd be lucky to get a set. brabus is expensive and doesn't lower that much. didn't even know kw makes a lowering spring set. eibach or h&r is easiest to get and should be good enough for the improvement you are looking for.
Old Jul 7, 2008 | 12:21 PM
bumpnzx3's Avatar
W203 C230SS
i'm happy with my h&r/koni setup.
