ATF, need helps!
Old Oct 1, 2008 | 06:36 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
ATF, need helps!
Do you know source to get ATF for C32 cheaper beside the stealer?
What is the brand, name, etc of ATF that the dealer uses?
Thanks,
Old Oct 1, 2008 | 06:46 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Originally Posted by CLKCLK
What is the brand?
Mercedes Benz
Old Oct 2, 2008 | 02:45 AM
CLKCLK's Avatar
Originally Posted by ScottW911
Mercedes Benz
Thank Scott,
I hardly believe if Mercedes manufactures transmission oil Otherwise, they would use Mercedes motor oil also instead of Mobil 1 right?
I got trans fluid from a local Mercedes & BMW part distributor here. It's Dexon III, Dexon III-H manufactured and imported from Germany. None account $14.xx/quart and $8.xx for reseller.
I got 9 quarts, and did the trans flush today. There was no torque converter plug in my trany???. I had tried to look very carefully but the only sign that might had been a hold were already welded so I only drained the oil from the pan, replaced filter, gasket, and 4.5 quarts of fluid. The old fluid was totally black. Maybe I got a bad radiator. The jerk seems gone, but don't know when/if it comes back. At least now it runs a lot better
Old Oct 2, 2008 | 04:50 PM
ScottW911's Avatar
CLKCLK,
Here is a very interesting write up, done by splinter, that will tell you everthing you need to know about type of fluid and the way to change it out.
https://mbworld.org/forums/showthrea...splinter+fluid
Good Luck.
