Faulty throttle body, CEL & ESP failure
Old Oct 10, 2008 | 04:24 AM
Jani Anttila's Avatar
C32 T-modell
I´ve had some serious problems with ESP failure & CEL. In the beginning it was very random and only CEL came up and it was just fine, not any other problems than light on dash. Then it started acting up more frequently and now it has both ESP & CEL, it has no power, revs just 1,5k. It does not go away by restarting...
Codes:
C1174, C1024, 066, 046
My tech first replaced gas pedal, but it didn´t make it any better. Now they are saying my throttle body is faulty, cost for replacement is 1000€.
My question is:
Is faulty throttle body common problem for C32?
I remember there being some service bulletin for TB wiring harness, i asked my tech to check it, but he said everything is fine with wiring.
Should i try to play with wires or just replace TB?
Old Oct 10, 2008 | 04:51 AM
N.M.M.'s Avatar
my throttle body has gone bad 5 times. always when i am out of town.... I will post more later, i have to run
Old Oct 10, 2008 | 09:14 AM
box986's Avatar
W211 E63
Codes:
My question is:
Had the same problem few years back, initially dealer thought it was the throttle body as well. 2 replaced and probelm came back (feels like throttle maintained at 1500 rpm in all gears, limp mode) in a few month.
Problem fixed after the engine wiring harness replaced.
Old Oct 10, 2008 | 09:44 AM
timberman's Avatar
silver 2002 c32 amg
I'm on number 4
the new version is different from the original and has AMG written on it which I don't recall seeing on the first
the part # for the latest version is A 112 141 03 25,
HTH
