240M3SRT's moddified intake manifolds available! Gain +32HP, +25TQ!!!!!!!!!!!!!!!!!!!
Did you (or anyone else who has installed these or the NEEDSWINGS) notice a drop in boost pressure? Correct me if my theory is wrong, but I would think that installing higher flowing manifolds would lower actual boost pressure measured at the MAP due to less resistance, even though flow is increased. If this is the case, the ECU would see less air even though the engine is actually consuming more air, causing the ECU to inject less fuel than needed. This theory would mean that a tune would be a MUST!
FinaLLY, SOMEONE is making sense!! I too only care about HOW quick and fast I get through those lights!!!
First don’t get me wrong. I really appreciate all information that you provide on your Modified Manifold Specification. I do not say yours doesn’t work as you have all the dynos to back it up. I just tell my experience and share what I have. I truly thought it would work based on the (simplified) theory “more air more power”. That was why I had this modification. However, it doesn’t behave the same on my car (for some reasons
). But It may behave good on others with ECU tune (since I don’t have a tune I don’t know
)I attach a pic of my modified manifold. Sorry, I did not want to take the Y split out since code3 intake makes the Y tight and harder to put it back.
I also have a gtech graph for the two similar run. Please the purpose is just for comparison between the two runs (before and after)
CLK
CLK
can't wait to get them and take the all motor title before MD lowers it again.
Which run is the run with the moddified manifolds. Im guessing its the red one.
Those Needswings manifolds are indeed nice, and have a nice $1500-$1600 pricetag too, as per post #461 in this link:
http://www.crossfireforum.org/forum/...=19961&page=24
For that price i believe you could have my modified manifolds, a tune of your choice, NW gaskets, and a little cash leftover to put towards spacers or an intake....oh and +32whp and 25wtq
That day he ran a 12.27 with everything above and adding the needswings mani's.
Here's what you didn't mention. He was the only one running the NW mani's with a LET tune. The other two in the 11's were from InMotion. So one would assume the tune is the difference, but worse was for some unknown reason to you or anyone else his LET tune went back to factory settings. So he basically was running no tune, and still managed 12.27. My InMotion tune was good for .50 off my time(12.52 to 12.02). Lets just say the LET tune is equal to that. With no tune and adding the mani's he managed to stay within .07 of his personal best.
I don't see where you think there was no gain with or without a tune for the mani's. Was the tune going back to factory inaccurate information from Distantpulse?
Also I might add these are for the SRT6 or SLK32 only. Sorry not for C32's. That's where 240 will help you guys out.
Also I might add these are for the SRT6 or SLK32 only. Sorry not for C32's. That's where 240 will help you guys out.[/QUOTE]
Based upon the photos, I do NOT see how these would fit the firewall area of an intake modded C32. We have little room NOW! With my Code/LET intake, I can't see these fitting?
My manifolds with tune will still gain power over stock but for the full potential you need a free flowing intake. The guy who used a gtech pro above looks like hes running a stock intake. You cant fully benefit from this.
Firewall shots of a c32 would be helpful, or if someone here lives in DFW id like to meet up and take a look. Id be very suprised if i couldnt come up with something....
Its hard enought just getting the sl55 splitter there...
I just want a chart of numbers with a side by side comparison of everything lol. No more endless searching and pages of reading for which size or style pulley is best, which headers are best log style or tube vrp style, which intake needswings, LET, C3 which heat exchanger lower temps C3 or LET, Best tune Inmotion or LET which manifolds Needwings or 240s. Every company has taken the time to do research and plenty of dynos who wants to step up and put this in a graph form that can be made a sticky for all to see and understand??? I would but my excel and power point skills would make you all laugh. Again it might be after the fact with LET not making parts anymore and a possible merger with C3
. Our track is closed ALL season except for the top fuel cars. Well, with the exception of one Sunday i hope i can make next month...I think we all want a chart like that lol unfortunately that chart is made by members who buy and test these products...
Ill let ya' know my results when i get my VRP headers on.
