Kenne Bell / Whipple setups?
Old Nov 5, 2008 | 07:23 AM
KrisR's Avatar
2002 C32
Coming from the Mustang / SVT Lightning world, I'm aware of Terminator Cobra and Lightning owners swapping their Eatons out for Kenne Bell or Whipple blowers and getting substantially more power at the same boost levels and enjoying lower IATs and such.
Has anyone adapted a KB or Whipple to our cars? Is it even possible? Obviously some custom work and a custom tune would be necessary.
Old Nov 5, 2008 | 07:40 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i've briefly looked into this as well. From what i'm aware of no one has tried.
I think the biggest problem would be the space issue. The engine bay in a c32 is pretty small in comparison to a mustang or truck.
Maybe you can be the first
Old Nov 5, 2008 | 07:54 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Hey KrisR:
What you need to understand is that the MB supercharger IS a Lysholm Screw blower, SO are the KB and Whipple. The Eaton is NOT a Lysholm Screw. With that being said, there is NO benefit to change the supercharger in the name of efficiency, as they are already the SAME design. Plus the MB supercharger has a Teflon coated lobe, to reduce heat. Now the gain COULD come form a LARGER supercharger, of the same Lysholm design, but that would take ALOT of engineering as our intercoolers are located underneath it, and the basic layout of our engines is NOT friendly to a larger supercharger. Hope that helps clear this issue up a little my friend.
See yeah
Old Nov 5, 2008 | 08:40 AM
viper501's Avatar
06 C55
What he said ^. The lysholm is so much more efficient of a blower than the Eaton / Roots style.
Old Nov 5, 2008 | 10:34 AM
c32used's Avatar
LET C32 2002
Old Nov 5, 2008 | 01:03 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
I thought the MB supercharger was an Eaton? In any event i was a supercharger.... twin screw, Lysholm, roots, whatever its all good to me i just want one.
Old Nov 5, 2008 | 04:27 PM
KrisR's Avatar
2002 C32
I see....so we basically have a little mini-Kenne Bell on our cars already. That makes sense. I was under the impression that it was just an Eaton.
The space issue is understandable.
Thanks for the info!
Old Nov 5, 2008 | 04:56 PM
CLKCLK's Avatar
03 C32 gone, 06 CLS55, 16 Tesla X
I do understand about the space issue with our car, but please look at the bright side of if. So supposedly, we can increase the size of our current supercharger to 2 cm taller and 2cm wider (this will only make the charger 2 cm taller and 1 cm wider on each side of the charger), with this small 2 cm increase in size, we can increase the diagonal of the impeller to 2cm. Please calculate how much more air it can blow under this mall change in side). Can you imagine with a larger volume of air at the same boot, how much more power you can gain?
Just for the area of impeller increased ratio: pi*(r+2cm)^2/pi*r^2 = ((r+2cm)/r)^2
Of course when air is increased, you need more fuel to adapt.
ECU tune is must to max out the gain but It is not impossible and for me it's worth a try.
Just my 2 cents so do not quote me
Old Nov 5, 2008 | 04:58 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Originally Posted by CLKCLK
I do understand about the space issue with our car, but please look at the bright side of if. So supposedly, we can increase the size of our current supercharger to 2 cm taller and 2cm wider (this will only make the charger 2 cm taller and 1 cm wider on each side of the charger), with this small 2 cm increase in side, we can increase the diagonal of the impeller to 2cm. Please calculate how much more air it can blow under this mall change in side). Can you imagine with a larger volume of air at the same boot, how much more power you can gain?
Just for the area of impeller increase ratio: pi*(r+2cm)^2/pi*r^2 = ((r+2cm)/r)^2
Of course when air increase, you need more fuel to adapt.
ECU tune is must to max out the gain but It not impossible and for me it's worth a try.
Hey go for it my friend
I would suggest contacting Whipple industries, as KB is Strickly a Ford guy. I could be wrong here, but I bought my whipple from KB a few years back. In any case full speed ahead and let the over boasting begin
See yeah
Old Nov 5, 2008 | 05:15 PM
SilverBulletAMG's Avatar
C32 AMG
That is a big problem with even modestly modded C32s. At this point we have a few on the boards that are being held back for that very reason. It's not as simple as tuning the ECU.
Old Nov 5, 2008 | 05:26 PM
TemjinX2's Avatar
I wish LET finished there turbo conversion kit before they broke up. I would rather have a turbo for around $6-7k then another supercharger for $5-6k.
Yeah the c32 supercharger is lyoshom supercharged manufactured by IHI in japan. I wish mercedes decided to use japanese electronics too..
Old Nov 5, 2008 | 05:49 PM
C32 AMG
DITTO!! TT FTW.
Old Nov 6, 2008 | 04:22 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
very good topic. I think I have covered this before on the Whipple supercharger.
There is in fact someone in Taiwan has already done it using the Whipple supercharger in place of the IHI. However this is a lot of work including using the M112 3.7L head+block and M113k pistons and rods, schrick cams, and other stuff. estimated more than 500hp conservatively. (basically it's not even a C32 anymore.) This is one of 5 C32 that had the 3.7L block and head conversion in Taiwan and the one that has the most work done.
total cost for that car in modifications along (including the brakes, wheels, suspensions, cooling, engine, tranny, etc) is 1.5 million NTD which is roughly $46800 USD. The car itself was 3.5 mil NTD brand new or more roughly $110-120k USD.
here's the link for the full article in Chinese. http://www.carnews.com/index.php?Mod...&division=Car1
Old Nov 6, 2008 | 05:03 AM
TemjinX2's Avatar
all i see are chicken scratches...haha..jk..Frank. Bah someone needs to take up the mantle and finish turbo conversion.
Old Nov 6, 2008 | 11:21 AM
c32used's Avatar
LET C32 2002
What makes you think there isn't one already
Please don't ask when the time comes it will be known
Old Nov 6, 2008 | 11:25 AM
c32used's Avatar
LET C32 2002
Looks promising but translate in english...only other language I can read is Spanish....soy Puerto Rican
Old Nov 6, 2008 | 11:29 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Whoa whoa whoa, LET broke up? Whad I miss?
Sorry, E guy straying in here to look around and noticed this. Most likely older news but kinda stunned me.
Old Nov 6, 2008 | 11:37 AM
240M3SRT's Avatar
CL 600
These kind of modifications are very expensive. Take a few hours to total up every nut and bolt you will need, no cutting corners...then double it.
There will be obstacles arise that you wont think of when you start. The first person will make a huge sacrifice financially as well as the time and hassle. If someone could translate and research as much about the car in Taiwan, it would be a huge stepping stone to start with.
Old Nov 6, 2008 | 02:31 PM
TemjinX2's Avatar
erick in texas is no longer part of LET. He was the one working on the hardware development. There was a post about it a month ago.
Old Nov 6, 2008 | 04:18 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
you can plug the link into yahoo or google translators...
Old Nov 6, 2008 | 05:26 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Yes, sadly, LET is changed. Jerry has taken on Wayne (Chicago X) as a partner to develop software only (not that that is a bad thing). It is just sad to see such cool hardware pieces go away. Erick will be missed too.
Oh by the way Jim, you are welcome to look around here any time. Just please post up some more of your great songs ("Chubby liquor store guy" comes to mind) when you drop by. Patronage; that was a classic. I really loved that diddy.
Old Nov 6, 2008 | 05:48 PM
c32used's Avatar
LET C32 2002
I have no idea how to do that either...oh well
Old Nov 6, 2008 | 05:56 PM
c32used's Avatar
LET C32 2002
Talking
Sorry you missed it but though somethings changed LET is still around.........some of the hardware may be gone but some like tuning, 181/185mm pullies, cm30, developement among other things are still around...Jerry is working with others to develope and introduce a variety of neat products and the stuff not sold anymore may reappear soon after all...just keep an eye here...as we take eventually a C32 into the 11s
Old Nov 6, 2008 | 06:46 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
I may be selling mine soon. I'll keep you posted. The last of the 2.8 Twin-Screw Autorotors...I WILL be going to the full 7.1 conversion and TT by Q1 2009.
