Hi.
I am trying to put together the let tube intake and I can't get the damn filter to go under the rubber tube connector. Is it supposed to be really tight or am I just doing something wrong?
My filters are HKS, 150-80 is what's written on the filter, but on the box it says
"Size 150X90"
"Diameter 80"
Is that what everyone else has?
maybe it's just that the rubber tubes are too tight. I have blue ones.
The rubber tube diameter is 74mm, the filter is 83 1/2mm (including the walls) can anyone confirm this? LET?
"Size 150X90"
"Diameter 80"
Nice sig, wish i could help
Quote:
it's cool Originally Posted by Tommy_s4
SPONSOR
loungn14
SPONSOR
close
- Join DateJul 2007
- LocationHouston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveEurocharged Performance ML63 and TT lambo
Liked:152 Times in 110 Posts
"Size 150X90"
"Diameter 80"
sounds odd. In my intake, the rubber tube coupler is larger than the tubes and filter, and needs to be cranked down a bit to get it to stay connected.Originally Posted by kindafast
Hi.I am trying to put together the let tube intake and I can't get the damn filter to go under the rubber tube connector. Is it supposed to be really tight or am I just doing something wrong?
"Size 150X90"
"Diameter 80"
Did you get the intake off another member or from LET directly?
Got it from the man himself Originally Posted by loungn14
sounds odd. In my intake, the rubber tube coupler is larger than the tubes and filter, and needs to be cranked down a bit to get it to stay connected.Did you get the intake off another member or from LET directly?
Went to autozone biggest they had was smaller than the one I have. I think a decent mechanic shop should have one.
Okay, I've been running around all morning and nobody seems to have them in a big enough size.
Where can I find one for sure besides the internet? I heard plumbing supplies should have it, will check that also.
