Front Left Signal Issues
Old Jan 23, 2009 | 01:19 AM
Donmun's Avatar
2002 S500
Does anyone else have the problem with the left front signal? for about a year now its been saying that i have to check the lamp but all the bulbs work fine. it flashes fast inside but normal outside. i purchased a replacement socket (because the dealer said there is a problem with the one that it came with) but the problem remains.
Any advise on this matter will be greatly appreciated. I refuse to take it to the dealer, they are trying to charge me almost $400 to change 2 gaskets that is held by 4 bolts that are on the top front section of the engine.
Donahue
Old Jan 23, 2009 | 10:32 AM
boohooramblers's Avatar
Not an AMG :(
Any advise on this matter will be greatly appreciated. I refuse to take it to the dealer, they are trying to charge me almost $400 to change 2 gaskets that is held by 4 bolts that are on the top front section of the engine....
Yep - the dealership will gladly take your money if you let them!
Have you checked fuses and relays for the signal lights?
Old Jan 23, 2009 | 11:39 PM
eclipsed's Avatar
2002 C32 amg, 1998 328i
Ditto for me
Except mine is left rear. all lights have been replaced and the problem comes and goes. I need to look inside the sockets for corrosion I guess?
Old Jan 24, 2009 | 10:32 AM
rockjock's Avatar
I DON'T COME HERE ANYMORE
my front left started this a week ago-I'm due for my B service, and under warranty-so I'm bugged....but thats about it. Had the MBZ for 3 months and been through more bulbs then my last 4 cars combined....must be all that powa the alternator is making at 120mph
Old Jan 26, 2009 | 01:17 AM
Donmun's Avatar
2002 S500
the fuses are OK, the lights still works so i doubt that the relays are bad, but i have to do further checks
Old Jan 26, 2009 | 03:47 PM
timberman's Avatar
silver 2002 c32 amg
wiring issue
I had the same problem a couple of years ago and couldn't find the source,
I took it to a local auto electrician I know who told me the problem was with the wiring harness which had started to short out and melt where it entered the headlight assembly, all he did was a simple repair which has lasted fine ever since
HTH
