Supercharger Pulley Problem
C32/C55 AMG
I finally managed to remove the supercharger pulley and as I began to press out the bearing, the pos 6 ton press snapped one of the bolts that supported the bench that the pulley was on. Well the pulley fell from the press and now it seems that the pulley is damaged. The back portion on which the belt rests is bent.
How would I know if I could still use the pulley? Was the 6 ton press too weak to take out the bearing, or did I just purchase a bad press?
I'll post pics soon.
Not sure how much an OEM costs, but I have a 7 month old Code3 pulley in great shape for $450 shipped. At least you can replace it and get some extra fun too.
2008 A8L, 2002 996TT X50, 2009 X5
IIRC, you can't source *just* the OEM S/C pulley from MB - it's unfortunately sold as the entire S/C assembly AFAIK. If your stock one is beyond repair, as Gramma mentions you might as well upgrade to the C3P one... you'd be lucky to find a stock S/C pulley for sale - most seem to hang on to them, in case they want to return the car to stock (although, I do remember recently, someone threw their entire S/C pulley away because the bearing was noisy... lol).
C32/C55 AMG
![](http://www.code3performance.com/C32/pulley1.jpg)
