Electrical problem with my seat, sunroof and dome
Old Feb 7, 2009 | 05:51 PM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
I didn't drive my car for about 3 weeks. When I found one of the door was left open, I closed the door and started the car, Car started fine. But now I have a problem with my seats it won't move back when I turn on or off the car, the seat motor is fine cuz it work when I try to adjust it manually.
My other problem is my sunroof, it works But it stops and I have to slide it back again. It's like when you disconnect the battery you have to set the sunroof. And my dome lights don't turn on when I open the door. But it work when I turn it on manually. Must be a memory problem or a fuse for it. Anyone had this problem before?
Old Feb 8, 2009 | 11:52 AM
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
Sounds like the drivers door switch. Behind the door lock striker is a switch, we replace them all the time at the dealership. As for the sunroof, it just needs to be lubricated and reset. To reset the sunroof, hold the button so it opens all the way and hold it for 3 secs when its all the way open. Then hold the button till it closes and hold again for 3 secs. Let me know how it goes and take a look at that door switch. Its a $12 part for the dealership.
Old Feb 8, 2009 | 10:42 PM
Trekman's Avatar
Fix the sunroof thanks now im gonna check the door switch
