C32 Y spliter
Old Feb 21, 2009 | 09:07 PM
gtr886's Avatar
E63 W211 08, C32 W203 02
Question C32 Y spliter
Hey guys, i broke the bottom clip on my C32 Y splitter when i was changing my Code3 intake filter. Does anyone know the part number for the splitter? When i order the spliter, does it comes with the rubber hose L+R?
Old Feb 21, 2009 | 09:14 PM
SilverBulletAMG's Avatar
C32 AMG
Several seemed to have broken their clips while doing that install. Most ran it as is or use a metal clamp on it.
C32Used has a stock one for sale in the classifieds I believe. You can try and PM him.
Splinter could probably give you the part number off the top of his head.
Old Feb 21, 2009 | 09:20 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
A lot of people have done that too. And although not ideal, I think most people do without it.
I just bought a SL55 splitter from MB via parts.com; I ordered 3 parts originally and they called me to say it's sold as one piece.
Old Feb 21, 2009 | 09:21 PM
gtr886's Avatar
How can you use a metal clamp? where do i clamp it? i afraid if i run it as it is, dirt or dust will get in the throttle body.
Or should i just buy the SL55 y splitter for the replacement?
Old Feb 21, 2009 | 09:22 PM
C32 AMG
Someone that's done it may chime in....
If you go with the SL splitter you won't be able to run the C3P intake you just installed which caused it to break in the first place. That would be a bit of a kick in the pants.
Old Feb 21, 2009 | 09:54 PM
boohooramblers's Avatar
Not an AMG :(
Apologies for omitting the air intake pipe (labeled '2' in the diagram) part # in this previous post.
The entire air intake pipe part # is 1120900129.
According to Mister Brenton's list, it is ~$65 (cost price) and $80 (dealer price).
SilverBulletAMG is right- the SL55 Y-splitter doesn't have a plate on the back of it so you can't use the C3P air intake.
Old Feb 21, 2009 | 10:05 PM
gtr886's Avatar
Thanks for the info, but I don't see the part number for the 2 inch rubber hose. So if I order the y splitter, it comes with it?
Old Feb 21, 2009 | 10:34 PM
Not an AMG :(
The rubber hoses to the left and right of the splitter? I'm pretty sure the tubes are included with the intake.
Old Feb 22, 2009 | 12:39 AM
advans's Avatar
C55 ///AMG, 535xi
PM sent.
Old Feb 22, 2009 | 12:48 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the clips not really needed. the rubber seal between the TB and the T-pipe is secure enough. I even run my SL55 airbox setup like that.
Old Feb 22, 2009 | 01:02 AM
gtr886's Avatar
my rubber seal is so old that is lose when the top clamp is locked. It rocks up and down when i move it.
