what do C32 owners think about motor swap
Old Feb 25, 2009 | 09:52 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
thats exactly what the c32 needs. more weight in the front..lol.
Old Feb 25, 2009 | 10:31 PM
c32used's Avatar
LET C32 2002
Talking
Originally Posted by lukep6470
The 2jz is a cast iron block with a cast iron head. It would destroy the handling and possible require a suspension upgrade.
2jz - over 700lb with transmission
C32 - around 550lb with transmission
Yeah but the heavier 700 hp makes up a bigger difference then the lighter 350 hp C32 engine
Old Feb 25, 2009 | 10:44 PM
TemjinX2's Avatar
well if your a dragster..then the extra power will make up for the weight.. Keep in mind these engines can go 1000+ hp
Old Feb 26, 2009 | 12:07 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by TemjinX2
you would need to swap out the heads too..since the supra head and the is300 heads are different.
I still vote turbo conversion.
i think the head was just different to allow the gte to feed the oil cooling upgrade?
have seen the 2jz-ge turboed with very good results and reliability. doesn't make as much power as the GTE obviously, but still insane regardless. lol
