Leaky C55
Leaky C55
After sitting much of the winter here in the midwest (what a winter) I moved my 2005 C55 and noticed a several small trans fluid spots (1.5inches in diamerter) and oil drops (quater inch) on the garage floor. Has anyone experienced similar problems? I bought the car new, the car has 20,000 miles and is not abused (driven hard but not abused).
I am going in on Monday for repairs and want to be able to point the dealer in some direction so it does not come back with the "cant replicate the problem" BS.
Thanks for your help.
05 C55
had the same. drivers side cam cover leaked oil, and there was a trans cooler line up near the rad that leaked. no biggie, stealership fixed them under warranty. took my car in at 49,xxx and thats the first time its been there....knock on wood...
Had the same issue with the left side valve cover gasket & 13 pin connector on the trans at 35K. If you search, there's another thread about this. Seems to be a common issue with the C55.
On my C55, the drivers side valve cover gasket leaked slightly (@30k) , the seal on the transmission multi plug leaked (@40K), and the main seal between the tranny & the engine leaked (@40K). All fixed under warranty. I believe that there have been threads about all of these fairly common leaks.
